4-speed Z
Old Mar 31, 2012 | 03:28 PM
hndumafia's Avatar
hndumafia
Default 4-speed Z
Seems like 5th gear is toast for me (and 6th is useless at the track..). The transmission seems to grind anytime i am shifting into 5th at any decent pace. I initially ordered some new transmission fluid thinking it might help, but the more I think about it, I assume it must just be the synchro going bad. I am pretty sure my transmission is not a CD009 since it was replaced way back in the day like 2004.
So my question is, is it worth trying to change the fluid, or should I be looking for a new transmission?
Old Mar 31, 2012 | 03:41 PM
0jiggy0's Avatar
0jiggy0
Takes minutes to change the fluid. Might be a synchro but a fluid change is cheap and easy. Give it a shot.
Old Mar 31, 2012 | 04:01 PM
hndumafia's Avatar
hndumafia
thanks jiggy. that answer is so reasonable, i hate that i even asked.
Old Mar 31, 2012 | 07:51 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Hopefully, you're using Redline MT85 for the tranny fluid change.
Old Mar 31, 2012 | 10:09 PM
terrasmak's Avatar
Don't waste your cash on the fluid , you need a rebuild.
Old Apr 1, 2012 | 08:44 AM
Transmission fluid is going to fix a broken transmission?
Old Apr 1, 2012 | 08:53 AM
white boy's Avatar
white boy
yea, new tranny or rebuild is needed
Old Apr 1, 2012 | 09:15 AM
reserved's Avatar
reserved
Welcome to the club. Unfortunately, its not exactly exclusive!!!!!!!!!!!
Old Apr 2, 2012 | 08:35 PM
hndumafia's Avatar
hndumafia
maybe old transmission isn't providing the needed lubrication for shifting gears? I don't really know what the extreme consequence of old/bad/worn fluid would be. It seemed a stretch since it's for only one gear, but I was hopeful!
I don't know much (anything) about rebuilding a transmission. Is this a viable option? I know the synchros are crap. Can a bad one just be replaced? Would it be much less expensive to rebuild versus buying a new one (and installing myself)?
Old Apr 2, 2012 | 09:43 PM
terrasmak's Avatar
Sorry bro, just doesn't work like that. You need to rebuild.
Old Apr 3, 2012 | 10:17 AM
DivZero's Avatar
DivZero
News trans can be found pretty cheap online. Whether that is cheaper and more durable than a rebuild probably depends on how labor rates and competent shop availability in your area.
About the redline MT fluid... I get better results from conventional transmission oil.. as do many when it comes to our specific transmission. I ended up buying Ford Motorcraft® SAE 75W-90 API GL-4 Gear Oil from a Ford dealer as it is much cheaper than Nissan's and seems to be higher rated from some online research.
http://www.fordparts.com/Products/Ch...ionFluids.aspx
Old Apr 9, 2012 | 09:40 AM
guitman32's Avatar
guitman32
Whats up Rajjjjj!
Im so amazed at how humble you are asking these questions, people are gonna think youre a newb and not passing vettes at the track, LOL!
New vs rebuild I say go new...even if it was feasible monetarily I HIGHLY doubt I would trust the tech enough to get it done and make the work stick. But then again you know how I am with trusting people to touch my car.
Old Apr 9, 2012 | 10:00 AM
guitman32's Avatar
guitman32
Oh and I like how you added the e92 to your sig...diiiickkk!!!!
Old May 15, 2012 | 08:23 PM
hndumafia's Avatar
hndumafia
Hi guys. I'd appreciate some advice regarding the transmission replacement.
I'm stuck between two options, new or used. I've found someone local selling a CD009 with approx 50k miles. Seller claims it was working in perfect condition with no grinding when it was removed. The cost is only $400. The other option is to go with a new transmission which I can get for ~$1800. Obviously this option should have no problems, and I will know that it hasn't been abused yet.
The savings of the used is pretty significant. But at the same time, I don't really plan on selling the Z anytime soon, and prefer to only have to do this job once. Spending nearly 20% of the current value of the car seems crazy though. I am back and forth in my mind.
The Z is only driven to and from track (hpde) events now. Either way, I will probably replace the clutch as well since it's pretty inexpensive.
Is there anything else i should consider replacing while doing this job?
Old May 15, 2012 | 09:27 PM
Then the seller will give you a written money-back guarantee? Say 50,000 miles?
Old May 16, 2012 | 08:58 AM
hndumafia's Avatar
hndumafia
Let's say yes about a money back guarantee but not 50,000 miles. At the current pace that would be more than 10 years anyway.
Old May 16, 2012 | 03:15 PM
hndumafia's Avatar
hndumafia
No opinions? Has everyone just sucked it up and bought a new transmission when they have had issues?
Old May 16, 2012 | 03:52 PM
dkmura's Avatar
dkmura
If you trust the seller, than go with the used tranny. I'd fill it with Redline MT85 and also replace the clutch slave at the same time.
Old May 18, 2012 | 05:14 AM
hndumafia's Avatar
hndumafia
thanks you, the redline is ready to go, and i will look into the clutch slave as well.
