Track Day Z Project
Old May 15, 2020 | 07:20 AM
  #401
Blurvision's Avatar
Blurvision
Originally Posted by Bak3rme
nice man! Hoping SCCA nationals this year isn't canceled @ Thompson. Are you going?
Naw. I dont usually drive with SCCA.
Old Jun 10, 2020 | 06:46 AM
  #402
Blurvision's Avatar
Blurvision
2020 season FINALLY got moving here. Got out to NYST with @camposrod send the Z TRAIN! had a blast, open track format. No instructing allowed yet. Lots of seat time
So, ALOT was changed over this extended pause in the season.
The 12s and brake ducts feel so much better than the 16s with nothing. Much more feel and bite. The 16s were not the correct pads for my setup. Very happy.
Tune is great power and RPM are a game changer. No more smashing the rev limiter or short shifting.
Now, the OSG diff has SO MUCH more grip I have surprised and impressed. Very noticeable improvement over the quaife. I was able to really put the power down much sooner. If you are on the fence at all about a high end diff just do it, worth it.
I am logging temp still and will report how its looking, so far was normal temps around 250f at NYST.
  #403
Blurvision's Avatar
Blurvision
Old Jun 24, 2020 | 03:26 PM
  #404
260DET's Avatar
260DET
Good news about the OSG LSD, my helical LSD is being changed for a OSG too so looking forward to that experience. Helicals are great in theory but my rear end has always been prone to a quick loss of grip on corner exit so fingers X for the OSG. My theory is that helicals either work 100% or else zero, no in between.
Old Sep 22, 2020 | 12:43 PM
  #405
Blurvision's Avatar
Blurvision
After NYST we made it off to Limerock in June. Still stuck in the 1.05s - 1.05.0 SO CLOSE
Getting used to all the new changes.
Old Sep 22, 2020 | 12:49 PM
  #406
Blurvision's Avatar
Blurvision
Next we did Lightning with Jeffapalooza! This is an invite only open track ALL DAY kind of event. 130 laps in one day!! wowoww.
Rear diff took a beating temp wise. Cooler to be installed.
Rod broke an axle so we swapped in a spare I carry.
I had to swap pads.
So much seat time..... endurance is key here
New PR 1.18.35 Very happy about that.
Old Sep 22, 2020 | 12:53 PM
  #407
Blurvision's Avatar
Blurvision
Old Sep 22, 2020 | 12:57 PM
  #408
Blurvision's Avatar
Blurvision
Here is a 30 lap log of various temps. Diff, Trans, Engine oil.
Diff cooler is coming soon!
Old Sep 23, 2020 | 11:39 AM
  #409
Blurvision's Avatar
Blurvision
Another trip back to jeffapalza. NJMP lightning again. New PR - 1.17.94
These events are super addictive. 180laps this time!!! Takes some real stamina. 1 - 1.5 hour stints.
Rod had a sidewall blow out on the R888. Scary stuff. Swapped to some used NT01 and dropped 1-2 sec on the same day.
Old Sep 23, 2020 | 06:47 PM
  #410
theronz-'s Avatar
theronz-
goddamn your car looks so good. The stance, big fat tires and clean oem body look...so very nice. Great job!
Old Sep 23, 2020 | 11:22 PM
  #411
260DET's Avatar
260DET
It does doesn't it, that shape has aged so well unlike the 370.
Old Sep 28, 2020 | 07:33 AM
  #412
Blurvision's Avatar
Blurvision
Thank you! Its fun keeping up this forum classic build journey with you all. ig @mhulbrock
Old Sep 28, 2020 | 10:43 AM
  #413
Blurvision's Avatar
Blurvision
Here is the diff cooler I made. Heavily influenced by the Alaria design. Just buy the kit! This was a ton work, I did save about $300 all said and done.
https://ma-motorsports.com/products/...ial-cooler-kit
Notable improvements. I added a inline filter.
The design made sure it did not hang too low. I put the cooler mount as close to the diff as I could fit it. Right now its always on fan / pump with key on. I would like to hook up some temp based trigger logic to my race capture for this.
Old Sep 28, 2020 | 11:10 AM
  #414
Blurvision's Avatar
Blurvision
Old Sep 28, 2020 | 11:41 AM
  #415
Blurvision's Avatar
Blurvision
Next event! Off to palmer with Masstunning. First time with this club, but I have been meaning to check them out for a LONG time. Very smooth event, got to instruct for the first time this year.
Diff cooler worked great, no leaks! Overal great day. Set a new PR. - 1.55.02
Turning out to be a great year for going faster!
Shout out to Tim @timmy_ton_ton we had some great drives that day together. Thanks for the fun lead / chase. Also the poke to update my thread here!
Old Sep 28, 2020 | 11:43 AM
  #416
Blurvision's Avatar
Blurvision
Old Sep 28, 2020 | 11:58 AM
  #417
Blurvision's Avatar
Blurvision
Ok all caught up now!
Last event for 2020 season is NJMP Thunderbolt. Had a really good crew show up this time. Had a blast doing some lead / chase all day. All the drivers run within 1-2sec of each other.
New PR!! 1.37.84
Old Sep 28, 2020 | 11:59 AM
  #418
Blurvision's Avatar
Blurvision
Diff cooler data! Note the temp rise by lap is much less severe. I need some more extended cession events to be sure.
Old Sep 28, 2020 | 12:00 PM
  #419
Blurvision's Avatar
Blurvision
Old Apr 29, 2021 | 06:25 AM
  #420
Blurvision's Avatar
Blurvision
2021!
I was poked a few times from you guys to re-boot this thread.
Were still here!!!! Plan is, go faster than ever!
First things first after 2020. Had to service the trailer. Been a LONG time. Not so exciting. New fenders welded on, new bearings breaks and drop links. Basically everything.
Surprisingly this made a massive improvement in towing stability. I guess I should have figured, I have no idea how old my steel beast trailer is.
