ST/SU Build
Old Mar 22, 2017 | 06:28 PM
  #341
Dblock55's Avatar
Dblock55
Small update, drivers side a pillar mount complete. Installed cage into car and mocked up A-pillar bars, hoping to get enough time tomorrow to bend them up!
Old Mar 23, 2017 | 08:07 AM
  #342
90nissanS13's Avatar
90nissanS13
Looking good! Things are moving along nicely.
Old Mar 23, 2017 | 08:23 AM
  #343
Dblock55's Avatar
Dblock55
Thx dude, to be honest the welding early on kind of discouraged me and then I got sidetracked and lost drive... now that I've got that down its just a time constraint.
Still not sure if I want to go asymmetric and do simple x-brace on passenger side and pushed out nascar style on drivers side, or spend the time and effort to do nascar style on both sides.... thoughts?
Old Mar 23, 2017 | 04:51 PM
  #344
90nissanS13
That area of the cage has been my biggest dilemma. The NASCAR style door bars are probably the safest. FIA typically use the X style with an A pillar of support, so I assume those are not a bad choice as well.
Unfortunately, you will never know how your cage will need to protect you. You can't build the perfect cage. You will need to look for the best compromise for the intended use.
The final decision I made for my cage is a hybrid between the NASCAR style and the X style. Where the X intersects, there will be no notch. Instead the tubes will bend away from each other and there will be a significant gusset the 1 instead the tubes will bend away from each other and there will be a significant gusset and stitch welded plates. This hybrid X will also not be in one geometric plane but, rather it will curve out torwards the door.
In addition to the hybrid in addition to the hybrid X brace, I will be inserting a large impact foam in the door.
Old Mar 23, 2017 | 04:53 PM
  #345
90nissanS13
I just did this with talk text, you will have accept the errors. Lol
Old Mar 23, 2017 | 06:25 PM
  #346
Dblock55's Avatar
Dblock55
I like the idea of packing the door with foam, lightweight but very effective at absorbing energy. Bent the a pillar bar... not sure if I'm going to stick to it or scrap it... upper part could have been longer to get closer to a pillar...
Old Mar 24, 2017 | 05:34 AM
  #347
BluestreamDE's Avatar
BluestreamDE
Nice Fabrication work on the cage!, Sub'd!
Old Mar 24, 2017 | 08:24 AM
  #348
Dblock55's Avatar
Dblock55
Thanks dude!
Old Mar 24, 2017 | 12:17 PM
  #349
90nissanS13
Oh man. I know you won't like this but, it's best to scrap that A-pillar. You need to have it as close to the body as possible. Set that on aside, you could probably use the material somewhere else.
Try laying out the A-pillar on the floor with tape and check it as you go. Leave the end sections longer than you need them so you can cut them to length.
Old Mar 24, 2017 | 07:56 PM
  #350
Dblock55's Avatar
Dblock55
FIXED!!
Old Mar 25, 2017 | 06:17 AM
  #351
90nissanS13
FIXED!!
Hmm 🤔 My concern here is now you just gave it another section where it could give and buckle...
Im not sure if that's acceptable.
Old Mar 25, 2017 | 06:28 AM
  #352
Dblock55's Avatar
Dblock55
Rules state each tube can have a maximum of 4 bends in it so technically it is acceptable. I will also be doing a fia type down tube from the roof bar down to the footing... this will help the main hoop support the load in case of a rollover, although even without it I don't think this design would fail... it will be gussetred to the a-pillar. On a side note 350zs had the best rollover rating of its time due to not having a door sill, engineers really reinforced the a-pillar, so overall I feel pretty confident about it.
Old Mar 25, 2017 | 06:56 AM
  #353
Dblock55's Avatar
Dblock55
Also the rules state you can have 8 chassis mou y points, #7 and #8 have to be to the firewall... is there a lot of benefit to be had fromthese? I'm guessing they would really protect you in case of a high speed front end impact. What's the best place for these? Drivers side seems pretty limited with the fuse box and pedals talong up that would side... thoughts?
Old Mar 25, 2017 | 05:02 PM
  #354
Dblock55's Avatar
Dblock55
Today's update!!! Would've completed windshield bar but power went out -_-
Old Mar 26, 2017 | 09:50 AM
  #355
Dblock55's Avatar
Dblock55
Roof bar in!!!! Thought id b able to wiggle it out to weld it up but its not having it... sigh. Itd b a lot more convenient to weld in gussets as well. Anyways, almost complete!!
Old Mar 27, 2017 | 07:48 AM
  #356
Dblock55's Avatar
Dblock55
Anyone in the Michigan area thatd b willing to let me use your car scales? Time to corner weigh the car but dont have access to the scales i did previously
Old Mar 28, 2017 | 03:25 PM
  #357
Dblock55's Avatar
Dblock55
What is everyone using for side netting inside the car and hans device? Any suggestions?
Old Mar 30, 2017 | 07:41 AM
  #358
GodISmE's Avatar
GodISmE
Apart from a few regular updates from the autocross guys this forum seems to be kapput, don't you think? It would be great to have a global forum section somewhere or a Facebook group purely dedicated to track prepped Zeds!
Old Mar 30, 2017 | 10:38 AM
  #359
03threefiftyz's Avatar
03threefiftyz
There already is...
Old Mar 30, 2017 | 11:02 AM
  #360
Dblock55's Avatar
Dblock55
There already is...
forum definitely seems dead... lame.
