ST/SU Build
Old Apr 6, 2016 | 05:23 PM
  #261
90nissanS13's Avatar
90nissanS13
Originally Posted by Dblock55
I know it's not much but finally broke ground on the cage. First 2 bends on the main hoop.
The ice has broken.
Old Apr 7, 2016 | 05:18 AM
  #262
Dblock55's Avatar
Dblock55
Originally Posted by 90nissanS13
The ice has broken.
^^^ I hope no pun intended because its F$*%KING SNOWING HERE!!!!! GODDAMN WINTER JUST WONT LET GO!!! Even in spring lol
Old Apr 7, 2016 | 01:04 PM
  #263
90nissanS13
AHAHA, no pun intended!
Although, it is warm and sunny here today. Apparently, it's a good day to take out the brand new 488 gtb
Old Apr 7, 2016 | 04:53 PM
  #264
Dblock55's Avatar
Dblock55
Got the cage in for some fitting, it was designed to be further back so it still needs to be cut...fits pretty well where it is not sure if I should keep it or move it... thoughts? The picture is where it sits now, was originally going to put it by the fuel pump housing. Like in the attached photo.
Old Apr 7, 2016 | 06:04 PM
  #265
90nissanS13
Nice LED...
Put it up on the bulkhead, further back. You don't want the main-hoop on the floor if you have other options.
Old Apr 7, 2016 | 11:56 PM
  #266
armt350z's Avatar
armt350z
^ this, the mid chassis crossbeam is a stronger point to mount to.
Old Apr 8, 2016 | 09:44 AM
  #267
Dblock55's Avatar
Dblock55
Nice LED...
Haha that LED light did have a plastic cover around it for about 2 seconds... been working for 3 years without it though, cant complain.
Was thinking bulkhead would be stronger, thanks for the confirmation. The only reason I was thinking of mounting it to the floor is for the door bracing... could the lower portion of the x will have to start pretty high if the hoop is mounted to the bulkhead.
Old Apr 8, 2016 | 11:28 AM
  #268
Blurvision's Avatar
Blurvision
Looking good, another vote for on the strong center cross beam. Added benefit is tons of room for seats.
Old Apr 8, 2016 | 12:04 PM
  #269
armt350z's Avatar
armt350z
Why do X at all? Maybe do a nascar door bar style
Old Apr 8, 2016 | 12:14 PM
  #270
Dblock55's Avatar
Dblock55
X-brace adds more rigidity
Old Apr 8, 2016 | 12:25 PM
  #271
armt350z's Avatar
armt350z
I'm not sure on that, got any data to support that statement?
Old Apr 8, 2016 | 01:48 PM
  #272
Dblock55's Avatar
Dblock55
Up on the bulkhead.
Old Apr 8, 2016 | 02:04 PM
  #273
Dblock55's Avatar
Dblock55
Shame on me.... i dont. My boss always says, an engineer without data is just another guy with an opinion. Without CADing it up I really cant confirm this theory, but I may just do it just to test the theory. Im going off of the general principal of bracing a flexing member. If you think of a cantilever beam, the higher the angle of the support the stronger the support. Obviously a chassis is way more complex than a cantilever beam loaded from a single point but for the sake of arguement, if you flex the front of the chassis relative to the rear the x brace will resist the flex, a tube that is in the same plane as the load will help a bit as the top bar will be placed in compression and the bottom in tension (or vice versa depending on the direction of the load), but since its parallel to the reference plane it wont be as effective as the x. Dunno if this is comprehensible lol.
Old Apr 8, 2016 | 11:58 PM
  #274
armt350z's Avatar
armt350z
Ahhh, Ok your referring specifically to chassis rigidity. I could see that, I was thinking you were talking about to rigidity of the bars in a side impact crash sequence. You could create a Nascar door bad that is compression loaded and improve upon the neutral loaded X bar. But it would require additional bars going from the main hoop to the back and front. Some of the Nascar bars that also connect into the door frame would probably be more stiff, but almost unanimously forbidden by most all sanctioning bodies.
I would run a Nascar bar on mine if I could, but FIA only allows X sadly.
Here is a 2012 cup car chassis, the door bars are loaded in compression and would likely resist any torquing of the chassis. Also any side impact would try to push the main hoop rearward, which is supported by the further bracing at the node.
Old Apr 9, 2016 | 06:10 AM
  #275
Dblock55's Avatar
Dblock55
Here is a 2012 cup car chassis, the door bars are loaded in compression and would likely resist any torquing of the chassis. Also any side impact would try to push the main hoop rearward, which is supported by ....
Very good point. I may go with x bar on passenger side and nascar on drivers side... safety is the overwriting priority. Thanks for the picture, good image to study.
Old Apr 9, 2016 | 04:41 PM
  #276
Dblock55's Avatar
Dblock55
Small update... cant believe how much time notching takes up
Old Apr 10, 2016 | 01:59 AM
  #277
armt350z's Avatar
armt350z
I ended up picking a harbor freight tubing notcher, with the 20% off coupon I had it cost all of $35 shipped. It is definitely a cheap tool but with some mild modification it worked well for what I was doing with it and saved me a ton of time.
Old Apr 10, 2016 | 04:46 AM
  #278
Dblock55's Avatar
Dblock55
What type of modification? Did you use it in a drill press of just a cordless drill?
Old Apr 10, 2016 | 07:55 AM
  #279
armt350z's Avatar
armt350z
It was a regular plug in type drill. I had to add a 1/8" shim the bracket that holds the tube so it was perfectly centered to the drill bit. Also buy some quality hole saw bits like a lenox and dont forget to lube up the shaft, since its using brass bushings instead of bearings like a high quality unit would have.
Old Apr 10, 2016 | 10:36 AM
  #280
armt350z's Avatar
armt350z
Here is the notcher I use, I also just saw a 20% off coupon code for a single item from harbor freight in my email. Coupon code says its for today only.
Notcher : http://www.harborfreight.com/pipe-tu...her-42324.html
Coupon code : 56391896
