NoVa 350Z track build
Old Sep 13, 2021 | 05:58 PM
  #201
Dr Hoon's Avatar
Dr Hoon
5 Year Member
Kinda OT I know, but I usually design the flyers for the local Audi club events, here's one I made for upcoming VIR DE
Old Sep 15, 2021 | 04:37 AM
  #202
redzedfl's Avatar
redzedfl
You will really like those SPL bushings and endlinks. I've been slowly replacing my bushings as they fail or get near to failure with SPL parts and I've been thoroughly pleased with all their products.
Old Sep 15, 2021 | 04:38 PM
  #203
Dr Hoon's Avatar
Dr Hoon
5 Year Member
Right. For the price they better be good.
Old Sep 26, 2021 | 06:15 PM
  #204
Dr Hoon's Avatar
Dr Hoon
5 Year Member
Fresh video of a few laps from Summit. Gotta say Michelin slicks are excellent, my lap time went from 1:28.8 in the spring to 1:26.2 yesterday. And then this morning I discovered the front toe was all out of whack, car pulling hard left. Didn't hit anything so not sure if I bent a linkage, destroyed a joint or maybe a wheel bearing. Will take it apart next weekend to find out what went wrong. Quite possible the grippy slicks overpowered whatever bit of OEM suspension are left in the front.
Old Oct 4, 2021 | 06:26 AM
  #205
Dr Hoon's Avatar
Dr Hoon
5 Year Member
Figured out what happened, the front left tire has failed, the belt has separated and the tire bulged out on one side. Might be hard to see in the pics, but the inside half of the tire is taller than the outside half. Fortunately I have 6 of these tires so I was able to mount a spare for upcoming VIR event.
I also noticed that the SPL front sway bar links I installed have shifted themselves. I guess having two spherical joins will do that, not sure if there's anything I can do to prevent this from happening.
While I was at it I went ahead and installed canards that came with my front bumper. They've been sitting on the shelf for a while and while I doubt there is much benefit to running them I figured might as well...
Old Oct 5, 2021 | 01:10 AM
  #206
RobPhoboS's Avatar
RobPhoboS
I have the same 'issue' with the SPL end links too.
I've tried adjusting them a few times but not quite sure how to get them so it's all lined up nicely like the instructions.
Old Oct 5, 2021 | 04:17 AM
  #207
Dr Hoon's Avatar
Dr Hoon
5 Year Member
Yeah, I realigned them but they are not gonna stay aligned very long. I guess it's fine as long as the movement is uninhibited, just kinda annoying if you have OCD :P
Old Oct 6, 2021 | 06:17 AM
  #208
Dr Hoon's Avatar
Dr Hoon
5 Year Member
I'm designing hood vents that'll fit in the middle of the stock hood right above and in front of the strut tower brace. Because of limited size of the 3D printer platter I'm making two mirror vents that'll sit next to each so they miss all the stock hood supports underneath and go right up to the hood crease on each side. More to come after I cut up my hood...
Old Oct 6, 2021 | 06:38 AM
  #209
RobPhoboS's Avatar
RobPhoboS
Nice !
I'm also planning on doing something like this, as well as what 350Z247 (youtube) with his rad venting/duct.
I would have loved to buy a hood that already had this stuff done but the pricing to the UK sucks! (plus it's a bit more fun cutting stuff up eh)
Old Oct 6, 2021 | 06:46 AM
  #210
Dr Hoon's Avatar
Dr Hoon
5 Year Member
Since my hood has already been scratched up in the tire wall incident, sanded in places and vinyl wrapped I figured there's no harm in cutting it up some more. Also, there is no weight advantage going with aftermarket hoods, and I'd have to install pins to hold it down. The only difficulty right now is printing ABS plastic that can withstand the temps on top of the engine. I've had to enclose the printer to build up enough heat so that the print doesn't warp off the plate, but even so it's still a bit touch-and-go.
Old Oct 8, 2021 | 04:23 AM
  #211
Dr Hoon's Avatar
Dr Hoon
5 Year Member
Printed from ABS using 1mm nozzle for max strength
Mock up location
Old Oct 8, 2021 | 11:34 AM
  #212
Dr Hoon's Avatar
Dr Hoon
5 Year Member
A couple more designs. The first one will sit on each side of the hood near the fender, the second will be right down the middle by the windshield. Since that's a low pressure spot I flipped it to be internal.
Old Oct 10, 2021 | 05:08 PM
  #213
Dr Hoon's Avatar
Dr Hoon
5 Year Member
Center hood vents installed
Old Oct 11, 2021 | 06:36 AM
  #214
Dr Hoon's Avatar
Dr Hoon
5 Year Member
If anyone would like to print their own, the design is now on Thingiverse. I'll add the side vents once I make sure they fit ok.
https://www.thingiverse.com/thing:5013931
Old Oct 12, 2021 | 08:29 AM
  #215
Dr Hoon's Avatar
Dr Hoon
5 Year Member
Side hood vents printed
Old Oct 12, 2021 | 04:57 PM
  #216
Dr Hoon's Avatar
Dr Hoon
5 Year Member
I got the side vents installed. Like before they follow the openings in the hood structure. I also added these to the Thingiverse download.
Old Oct 14, 2021 | 02:34 AM
  #217
Derek King's Avatar
Derek King
those are great. Thanks for sharing
Old Oct 14, 2021 | 08:09 AM
  #218
GreyZ's Avatar
GreyZ
Those vents seem a bit farther back that I would have expected. Any reason on why you chose so far rearwards? or was it based on hood structure.
Old Oct 14, 2021 | 05:44 PM
  #219
Dr Hoon's Avatar
Dr Hoon
5 Year Member
Yeah, the hood structure played a big part in vent location. Also I figured this way I'm not only improving the radiator airflow but also providing a bit of extra cooling for the engine.
Old Oct 15, 2021 | 01:05 AM
  #220
RobPhoboS's Avatar
RobPhoboS
Julian Edgar has some really useful videos and books too on all of this kind of stuff (lots of practical stuff):
https://www.youtube.com/c/JulianEdgar/videos
Worth checking out, and reminds me I need to buy a couple of his books too !
