Who's running Toyo RA-1s?
Old Mar 29, 2007 | 07:34 AM
  #41
mhoward1's Avatar
mhoward1
Originally Posted by z-u-later
Have you driven these RA-1s on an autocross or road course yet? I'm just curious to see how they handle. I went with the RA-1s so I'll be able to drive to the track & back since I don't have the ability to pull a trailer yet.
I have run then on Road Atlanta and VIR Full, and VIR South so far. For S&G I took them out on the street Monday. Exit ramps on R-Compounds are a bunch of fun.
Old Mar 29, 2007 | 08:23 AM
  #42
z-u-later's Avatar
z-u-later
Awesome! I'm looking forward to slapping these RA-1s on my track rims this weekend!
Old Mar 30, 2007 | 08:55 AM
  #43
first350's Avatar
first350
If you're looking for another option, look at Hankook. I have their C70 275/17's and they're great; I've run RA-1's, and the Hankooks are much stickier...I got the softest rubber they offer b/c I'm doing AutoX. If you're looking for something that will last longer, then get their C30...C70 is their softest, C50 middle, C30 harder.
Hankook Ventus Z214
http://www.hankooktireusa.com/produc...ail.asp?pid=58
-Peter
Old Mar 30, 2007 | 02:22 PM
  #44
tmak26b's Avatar
tmak26b
Lap in June with Rt-615, brand new set, 1:059
http://video.google.com/videoplay?do...11961269&hl=en
Lap in October with completely bald RA-1 that I pulled from the dumpster, 1:029
http://www.youtube.com/watch?v=vICXp_KOJC8
Car was crusing at 1:04 effortlessly too, i was doing 1:07 before
Old Mar 30, 2007 | 02:23 PM
  #45
tmak26b's Avatar
tmak26b
For autox, I used the same set of tires from the dumpster. I ended up getting about 6 top 10s (overall) and 1 FTD in the rain on the slicks....
Old Mar 30, 2007 | 04:05 PM
  #46
dnguyent's Avatar
dnguyent
It looked like you were driving in the snow! Perhaps you can zoom in a bit so the aperture is set to the light outside instead of inside the cabin. Your tires were screaming in pain though...nice.
Old Mar 30, 2007 | 08:35 PM
  #47
tmak26b's Avatar
tmak26b
It's hard to do when you use a security camera using AV input to record with a camcorder. It looks better in higher resolution, but i cant post anything bigger.
The word Z goes with tire screaming and brake wearing down...
Old Mar 31, 2007 | 12:56 PM
  #48
mberthia's Avatar
mberthia
These are the tires I received from John Berget Racing. Is this consistent to what you have received? They are the best tires he had at $70 each, full rubber... First picture is the best tire. What do you think ?
Attached Thumbnails Who's running Toyo RA-1s?-p1010012a.jpg   Who's running Toyo RA-1s?-p1010013a.jpg   Who's running Toyo RA-1s?-p1010014a.jpg
Old Mar 31, 2007 | 01:30 PM
  #49
MoodDude's Avatar
MoodDude
These are shaved RA-1's that have been heat cycled. They look like they have about 1/2 the shaved depth still left. Once you roll on them one time they will clean themselves up, so don't worry what they look like right now.
Old Mar 31, 2007 | 05:37 PM
  #50
daveh's Avatar
daveh
Those look good. They're almost at the point where they'll be their fastest.
On an RA-1, any time you see 4 grooves, you've got a lot of rubber left.
Old Mar 31, 2007 | 06:21 PM
  #51
z-u-later's Avatar
z-u-later
The set that I received from Berget Racing looks similar in wear, with the four grooves still showing in each tire. I did notice though that all four of the used RA-1s that I bought had slight shoulder wear. Does anyone know if it's alright for me to flip the RA-1s? The label on the side states they're directional but when I look at the thread pattern (grooves), I would think I should be able to flip them. It looks like it really does not matter which direction they're mounted. Anyone?
Old Mar 31, 2007 | 07:03 PM
  #52
daveh's Avatar
daveh
Yes, you should flip them on the rims at about half way through their life. Even before you notice inside wear.
Toyo's website used to have a suggestions page with recommended temp ranges and camber suggestions. On that page they said to flip them half way through their life.
Old Mar 31, 2007 | 08:31 PM
  #53
tmak26b's Avatar
tmak26b
Here is a tip. If you drive a STOCK Z and drives it hard, I recommend flipping them every 2 to 3 events....
Old Apr 1, 2007 | 01:56 PM
  #54
mberthia's Avatar
mberthia
What will be the first sign telling me that there is not much rubber left ?
Also, for dismounting or flipping them, you mean moving a right side tire to the left side while keeping the rotation in the same direction ?
Old Apr 1, 2007 | 02:03 PM
  #55
tmak26b's Avatar
tmak26b
just take one tire, remove it for the rim and flip it so the outside becomes the inside.
Drive the tire until you see cord or they dont grip anymore
apex locator
Jul 23, 2021 02:27 AM
350Z_Al
Oct 29, 2020 07:44 PM
