DIY - Hood Damper/Hood prop!
Old Sep 30, 2007 | 11:06 AM
  #81
6894kevin's Avatar
6894kevin
I want to post some pic's but it's not working, if i figure it out i will post some.
All in all it worked great!
Old Sep 30, 2007 | 11:11 AM
  #82
6894kevin's Avatar
6894kevin
[img]https://s193.photobucket.com/albums/z142/6894kevin/?action=view&current=Nissan350Z023.jpg[img]
Old Sep 30, 2007 | 11:14 AM
  #83
6894kevin's Avatar
6894kevin
Hope this works
[IMG]http://s193.photobucket.com/albums/z142/6894kevin/?action=view&current=Nissan350Z023.jpg[IMG]
SCREW THIS I give up.
Anyway it looks great and works great, thanks for the brackets and this DIY was easy as cake.
Old Sep 30, 2007 | 12:27 PM
  #84
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Nissan350Z023.jpg?t=1191184077
Fixed
Old Sep 30, 2007 | 12:46 PM
  #85
6894kevin's Avatar
6894kevin
thanks man, but how do i post a pic instead of a link??
i thought i was doing it right but still managed to screw it up.
cheers
kevin
Old Sep 30, 2007 | 12:51 PM
  #86
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
The site where you have the photo at will not allow you to show photos like that. You will have to use another photo site.
Old Sep 30, 2007 | 12:59 PM
  #87
JasonZ-YA's Avatar
JasonZ-YA
nice work guys....
the lengths of the lift supports are important...i played with a few before getting it just right....
looks good!
- Jason
Old Dec 7, 2007 | 01:49 PM
  #88
buffmanjeff's Avatar
buffmanjeff
Just an update, Napa sells the metric ball stud to use so you dont have to weld or tap. Napa part number 735-3608. I had to buy these for the Tein dampers since they changed their design and no longer provide them.
Old Dec 8, 2007 | 11:02 PM
  #89
JasonZ-YA's Avatar
JasonZ-YA
WOW REALLY! Im gonna go look into that...so they were M6 metric treading???
-jason
Old Dec 9, 2007 | 03:51 PM
  #90
6894kevin's Avatar
6894kevin
Why Doesn't Nissan Do this at the factory??? It works so much better IMO
Old Dec 11, 2007 | 04:46 PM
  #91
JasonZ-YA's Avatar
JasonZ-YA
Default No More Need To Weld! Sweet Find!
THATS SWEET!!! I looked everywhere on the internet and around town including NAPA...dont know how i missed it....Thanks!
MEGA UPDATE!
THANKS TO ( buffmanjeff ) for his post 88. He found that NAPA sells the ball stud needed so that you DO NOT need to tap or weld...
This find makes this how too way easier to an already easy how to.
see attached pics.
1. Remember you only need two of the napa p/n 735-3608 ball studs per car. they mount on the fender factory bolt hole location. NAPA P/N 735-3608 COST 5.14 EACH!
2. You still need two NAPA part number: 735-1591 - 5/16 thread ball studs for the angle mounted on the hood. I doubt the p/n 735-3608 would be good to use for the hood location due to the size and short length of the shaft. you can torque down the 5/16th ones more. besides they are cheaper and easier to work with.
- Jason
Attached Thumbnails DIY - Hood Damper/Hood prop!-img_3531.jpg   DIY - Hood Damper/Hood prop!-img_3530.jpg   DIY - Hood Damper/Hood prop!-img_3532.jpg   DIY - Hood Damper/Hood prop!-img_3533.jpg
Old Dec 24, 2007 | 06:50 AM
  #92
eganx's Avatar
eganx
Post 42 lists the part number for NAPA lift support as BK.819-5517, but your edit to post 2 has UPDATE: LIFT SUPPORT MODEL # BK.818-5517 60LB.
Searching the NAPA site, it looks like BK.819-5517 is the correct part number.
Old Dec 25, 2007 | 09:06 PM
  #93
JasonZ-YA's Avatar
JasonZ-YA
thanks....got it fixed now...
-j
Old Jan 10, 2008 | 08:49 AM
  #94
DraGonAlchemist's Avatar
DraGonAlchemist
Originally Posted by JasonZ-YA
HI,
After looking at multiple hood prop designs I decided to come up with my own. This is my first try at this and it works great. but Im gonna revise the angle mounted to the hood screws because i used to thin of aluminum for testing purposes and its too weak. If you look close enough you can see the aluminum yielding.
after many responses from everyone wanting me to make a DIY I decided to help the z community out.
Please dont post anything till im done. HERE GOES!
IM NOT RESPONSIBLE FOR ANY DAMAGES FOR ANYONE ATTEMPTING TO DO THIS INSTALL.
- J
UPDATE:
IF ANYONE WANTS ME TO MAKE THIS FOR THEM. PM ME AND I CAN HAVE THE ANGLE FABRICATED, HOLES DRILLED STUDS MOUNTED AND ALL. PM ME FOR SHIPPING AND PRICE. IF YOUR LOCAL COME OVER AND WELL FAB IT TOGETHER IN MY GARAGE!
- J
not a bad fab man. .but it looks to me that the pistons you used are pretty big. .i just got my tein's in and installed them in 10 minutes. .and they are pretty small. .and tuck in nicely with no hood waking. .all the curves and lines measure up perfect as if i never installed them... i was thinking of making my own as well. .but just went with buying it cause when you do the math for the price i got mine at it's about 20 bux off. .
Old Jan 10, 2008 | 08:56 AM
  #95
JasonZ-YA's Avatar
JasonZ-YA
cool....glad you like yours...
ya, ive seen them before and they are a bit skinnier....but its not by much.
there is NO hood waking with my design.
post up some pics of yours.....
take care.
laterz
- Jason
Old Jan 10, 2008 | 09:13 AM
  #96
DraGonAlchemist
Old Jan 11, 2008 | 06:27 PM
  #97
JasonZ-YA's Avatar
JasonZ-YA
cool....
Old Feb 2, 2008 | 03:39 PM
  #98
XenoJC's Avatar
XenoJC
Originally Posted by frankmusic
2. Straight out of the box, these dampers almost seem to be frozen. To loosen these up a bit, completely compress the hood dampers about 50 times each. If you choose not perform this step, you may run the risk of damaging your hood hinges or even the OEM hood itself. The factory hood is fairly light and more than likely flex before the extremely stiff hood dampers actually retract.
I just bought one and noticed that also. I can't even press them in. They are rock hard. Is there a trick to it?
Old Feb 3, 2008 | 11:39 AM
  #99
6894kevin's Avatar
6894kevin
I got a couple of scrap pieces of 2x4, and put one on the ground and the other on the other end of the prop and just pushed it down several times. Put your weight into it and it shouldn't be that hard.
Good Luck
Cheers
Kevin
Old Jun 14, 2008 | 07:43 AM
  #100
Mike M's Avatar
Mike M
UPDATE: LIFT SUPPORT MODEL # BK.819-5517 60LB.
COST: My local NAPA $21.99 each.-j
Damn I wish I found this thread earlier in the day, called my local NAPA but can't get the parts in from the warehouse til monday, Stupid thing is the warehouse is closer to me at the moment than the Napa store is but they don't sell over the counter there on saturdays
Can you guys post up some pics of your DIY brackets to get an idea of what I should have? Planning on making a set of those today so I can just install it all Monday.
