Sway Bar Database
Old Aug 4, 2016 | 10:20 AM
  #141
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
Are those oem sway bars painted red?
I'll get a picture of the ends of my sway bars later and report back.
Old Aug 4, 2016 | 11:54 AM
  #142
dboyzalter's Avatar
dboyzalter
Ok so they look bent for sure compared to oem... Anyone else impressed with how beefy the oem bars are?
Well the front one is anyways.
Old Aug 4, 2016 | 11:58 AM
  #143
Vajk's Avatar
Vajk
Thank You! I hope you are not right. I don't want to be scammed. In my first post I mentioned that the diameter of they sways are differ from the other aftermarkets, but I also think, they differ in size from the oem ones. I tried to measure the weight of them, and I think they seemed to be heavier then the oem ones. Sorry for my english.
Thank You for the pic. I didn't see them when I posted 3 minutes ago.
What are your opinion? Do I need to correct the angles, or it's not a big deal?
Old Aug 4, 2016 | 05:08 PM
  #144
dboyzalter's Avatar
dboyzalter
They dont seem like oem because they have a rounded end, and they look like the end pieces are welded on... They definitely look aftermarket. I wouldn't imagine the slightly off ends would make a big difference. The end links have ball mounts that freely rotate. I wouldn't be excited about them but im sure they will work. If you had a large vice and a torch you could try straightening them but I think that would do more harm then good.
Old Aug 5, 2016 | 12:16 AM
  #145
Vajk's Avatar
Vajk
Thank You for your input! I am not absolutely certain about this, but maybe I read that the oem sway bar links are weak for the aftermarket bars. Do I really need to buy some aftermarket links, or the oem-s are OK?
Also I mentioned before that the new sway bars have smaller diameter then the oem-s "The front one is 23.75mm, and the rear one is about 19.75mm." Do I need to buy new bushings? I didn't find the proper sizes on ebay...
Old Aug 5, 2016 | 01:09 PM
  #146
Vajk's Avatar
Vajk
Ok. I think, the bushing case is solved. I found some friendly dealers in Hungary!
My question about the links are remained the same. Should I buy new ones, and if so, can you suggest me some good deal in reasonable price? Thank you and have a nice day!
Old Aug 5, 2016 | 03:23 PM
  #147
dboyzalter's Avatar
dboyzalter
What's wrong with the oem end links?
Old Aug 5, 2016 | 05:32 PM
  #148
MicVelo's Avatar
350Z/370Z Tech Moderator
Generally speaking, with a single/non-adjust bar like yours (or OEM) and the car is not severely lowered, OEM links are fine.
The main reason for wanting a stronger end link is for the angle adjustment (spherical link) when using multi-hole adjustable bars that change the angle at which the bars attach to the links, sometimes resulting in excess bind and pre-load. The spherical end link (ref'd to as "pillow ball mounts" on some) allows you to properly unload the bars at static.
But even with adjustable bars, stock links work fine UNLESS severely lowered, and the angle of the control arms arms are significantly altered from stock. Also, if you are running the bars full-stiff, you might want to install the adjustable links due to the increased angle of the mounting position.
Last edited by MicVelo; Aug 6, 2016 at 09:01 AM. Reason: gramur coreckshun and more detail
Old Aug 5, 2016 | 10:53 PM
  #149
Vajk's Avatar
Vajk
Now that is good news. Thanks!
Old Aug 12, 2016 | 11:06 AM
  #150
Vajk's Avatar
Vajk
Guys! I can't decide!
The rear sway bar is 19,4mm. If I buy 19mm bushing, I must cut it somewhere, because I won't be able to install it other way.
Like this:
If I buy 20mm, installing it will be easy, I won't need to cut the bushings. But maybe they will be too lose, they will lose lubrication and collent junk.
What are your humble opinions?
Old Aug 12, 2016 | 12:08 PM
  #151
MicVelo's Avatar
Like this:
Sway bar didn't come with replacement bushings??
Whatever the case, 19 and enlarge to fit. We're talking 0.4 mm not even half a millimeter. Not hard to hone out that much. Heck, the 19 will probably fit from compression once slipped around the bar and the saddle bolted up.
Old Aug 12, 2016 | 11:19 PM
  #152
Vajk's Avatar
Vajk
Dear MicVelo!
Thank you for your advice. My first idea was also to hone out some "meat" from the inside of the bushing. Unfortunately the owner of the webshop told me that the material of the poliuretan bushing needs special machine work to modify, so I wont be able to make a bigger hole only with some sharp tool. I don't know the truth about it, because I never had this piece of stuff in my own hand.
Old Oct 7, 2016 | 07:27 PM
  #153
n_den's Avatar
n_den
hey all, got this from a mod:
Originally Posted by dkmura
Welcome and as far as handling goes, upgrading the swaybars will make a huge difference with a Z33.
i replyed
Originally Posted by n_den
cool, would replacing just the rear sway bar be enuf? also, my z32 has poly bushings with OEM sways, whats the minimum poly bushings i can change out on the z33?
thanks!
then i saw this thread, figure i repost it here. thanks. n_den.
Old May 23, 2018 | 10:23 AM
  #154
Eigen's Avatar
Eigen
Default H&R Sway bar weights
Just received my H&R sways in the mail and weighed them.
For future reference:
Front: 11kg ~22lbs
Rear: 4.5kg ~9lbs
This was done on my bathroom scale, so take it as a ballpark.
I guess that's what a 36mm solid bar of steel weighs...
Have to say though, workmanship and fit/finish are excellent, very high quality pieces.
hulkout
Apr 28, 2017 09:00 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
