Stoptech 13" Front Brakes
Old Jun 13, 2005 | 12:10 PM
350GT's Avatar
350GT
Default Stoptech 13" Front Brakes
I just ordered them.
But I haven't seen any pictures of a red 13" stoptech front brake kit on a 19" rim. I'm hoping it wont look too small.
Anyone got pictures?
And, how does this 13" kit compare to the Brembo's on the Track? Which are bigger?
Old Jun 13, 2005 | 01:02 PM
Audito350Z's Avatar
Audito350Z
Stoptechs are 13.1", OEM Brembo are 12.9"
Old Jun 13, 2005 | 09:14 PM
zzzya's Avatar
zzzya
They will fill the rim space nicely. I have the silver 13" kit on the front with 19" Volk LE37ts. The nice thing about the 13" kit is that it doesn't add as much weight and you can still use a 17" wheel if desired.
Old Jun 13, 2005 | 09:26 PM
430ztt's Avatar
430ztt
is that a proven fact about being able to use the stock 17s with the Stoptech 13" BBK???? I have been trying to find someone that has done it themselves and not just heard that it fits. I dont want to spend the money on a 4 wheel BBK that I think will fit with the stock 17s only to find out it wont. I know the track model Brembo's fit with the stock 17s no problem and have seen that in person.
Old Jun 14, 2005 | 04:39 AM
GaryM05's Avatar
GaryM05
I have the front 13" StopTech kit under the 17" OEM wheels, and I can tell you for sure that it fits. Not 100% sure on the rears, but I would suspect that they would fit, too. A quick call to StopTech could probably confirm that for you, though.
Old Jun 14, 2005 | 06:54 AM
Z-Z's Avatar
Z-Z
I also have the 13" Stoptech kit under the 17" stock wheels. It does fit.
Old Jun 14, 2005 | 07:49 AM
J Ritt's Avatar
J Ritt
Hi guys,
Our 13.1" (332mm) Front and 12.9" (328mm) Rear setup with the 2-piston caliper in the back will fit under the stock 17's, Touring 18's, and Track Model 18's. I have personally seen all of them, and no fitment issues. In fact, I personally ran stock 17's on my front 332mm setup at one point.
Old Jun 14, 2005 | 04:38 PM
ppw350Zunit's Avatar
ppw350Zunit
just wondering how much you got them for?
Old Jun 14, 2005 | 04:48 PM
apharmdb's Avatar
apharmdb
I'm going with the 13 inch front kit too, hopefully very soon and I know it fits under the 17x9 +27 wheel I use for track duty. Seen some pics of it recently on this board.
Old Jun 15, 2005 | 01:17 PM
bwzabodyn's Avatar
bwzabodyn
I'm looking at getting a 13" front kit only in silver for the time being ($$$ being an issue) and later upgrading the rears as well... zzzya, do you have any pics of the setup? I have a BS G35 coupe and Merc Silver Winnings and wanted to keep the silver theme going (it's going to be either silver or black - I have the front inserts of my nismo bumper painted black and also the rear diffuser area between/around the exhaust tips painted black, so it could go either way) - thanks (if you get a chance to post a pic that is )
Old Jun 15, 2005 | 01:22 PM
J Ritt's Avatar
J Ritt
Yes...our rear 2 piston can be added at any time...not an issue at all. I often recommend this route to my customers. I tell them to get the fronts when they need them, and add the rears later IF they need them. Some people eventually do, others find that the fronts are sufficient for their needs, budget, etc.
Old Jun 15, 2005 | 01:58 PM
barthelb's Avatar
barthelb
Master
Can you do the 14" FR kit only in silver. Then add the rear later?
Old Jun 16, 2005 | 08:58 AM
430ztt's Avatar
430ztt
J Ritt, do you know if your 4 wheel 13" BBk would fit if I had 17x8.5 wheels with a +31 offset on all four corners? I am interested in a BBK and a set of SSR Comp-H in the size mentioned but don't know if I would have any clearance issues...
Old Jun 16, 2005 | 11:47 AM
J Ritt's Avatar
J Ritt
430ZTT,
I don't know if that wheel will fit or not. Check the wheel fitment charts on our website to be certain. Call the vendor you are planning to buy the wheels from, and have them check for you. They should be happy to take a couple of minutes and do this if they're about to make money off of you selling you wheels. If you are using Tire Rack, ask for Luke Pavlic. The charts very easy to use:
http://www.stoptech.com/wheelfitchar...hart_index.htm
Obadabot
Jun 18, 2023 11:31 PM
samansharif
Sep 25, 2015 12:31 PM
