Tokico D-spec shock+Tanabe GF210
Old Aug 5, 2006 | 07:18 AM
Super Avan Z33's Avatar
Super Avan Z33
Default Tokico D-spec shock+Tanabe GF210
Just want to know has any body running this set up on their ride, how is that compare with stock and what is the max drop that we can get, any pics will be great.
Thanks
Old Aug 5, 2006 | 07:34 AM
Gsedan35's Avatar
Gsedan35
Tanabe GF210 Series 350Z progressive springs 1”/1.2” drop
Spring rates in LBS 336/375
Curious, why not go with the Tokico D-spec shock and spring setup?
Tokico 350Z linear springs 1"/1" drop
Spring rates in LBS 375/375
Old Aug 5, 2006 | 07:47 AM
Super Avan Z33
I already had the Tanabe GF lower spring on my car for over half year, I like them and just want some advice on the Tokico D-spec+Tanabe GF combo set up, the stock suspension is too soft for me when cornering.
Old Aug 5, 2006 | 08:38 AM
zman1910's Avatar
zman1910
Did the springs alone make a big difference in handling?
Old Aug 5, 2006 | 08:48 AM
Gsedan35's Avatar
Gsedan35
You'll get more of what your looking for with the Tokico shock and spring setup. However, you can adjust the D-spec shocks to be stiffer then 04.5+ oem shocks and slightly stiffer vs 03/04 oem shocks. Be advised that a 1.2" drop with just a mild spring rate increase that the GF210's have will mean you have some issues relating to suspension travel (bump travel), turning up the D-specs high may or may not save you in that regard.
Old Aug 5, 2006 | 04:32 PM
Super Avan Z33
Let's say, if I go with this set up (D-spec+Tanabe GF) and turn the D-spec shocks to the highest stiffest level, what kind the main major issue for me to look out?
Old Aug 5, 2006 | 05:21 PM
vince1611's Avatar
vince1611
Old Aug 5, 2006 | 06:17 PM
Gsedan35's Avatar
Gsedan35
1. That you will have enough suspension movment for the given road condition's you frequent as to allow proper tire contact at all times.
2. Or that your just tightening up how the chassis behaves when your bump stops are bouncing off the tops of the shocks, while driving straight and around corners. Here's a thread about Koni shocks with GF210 installed, notice the complaint. https://my350z.com/forum/showthread....ht=koni+bounce
Old Aug 6, 2006 | 05:50 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
I've run this combo before on a couple of local cars....has worked out great. With the tanabe's in the car, the trick is to actually firm the koni's up, not make them softer - their low speed dampening characteristics are not the greatest, especially when combined with 19 inch wheels and low aspect ratio tires. Takes a bit of playing around to get them perfectly dialed in, but once there, it will work well. Alot of the overal ride quality on any suspension is relative to the tires you're using, and the pressure's you run - they all work as a unit.
I have not used the D Spec's with anything other than D Spec springs as of yet
Old Aug 6, 2006 | 06:35 PM
Super Avan Z33
I guess no body run this set up before, I may give that a try see how things work out, since I already had Tanabe lower spring on my car, now I just need a set of D-spec.
Thanks for all infor...guys
Z_flip
Feb 17, 2014 09:09 PM
(ZzzzzZ)
Apr 16, 2012 10:52 PM
Swifty
Apr 25, 2007 07:53 PM
Roger V
Jan 8, 2007 12:53 PM
wesismyhero
Jul 24, 2006 08:11 AM
