developing camber and traction rods for rear, any interest?
Old Oct 9, 2003 | 07:34 PM
  #81
JPG35C's Avatar
JPG35C
Here is the pic of my car w/5Zigen's/Eibach's
Old Oct 9, 2003 | 11:32 PM
  #82
Gsedan35's Avatar
Gsedan35
Originally posted by lsdunique:
camber arms - $220
traction arms - $235
If you buy the set of camber and traction rods, you can get both sets for $400 even.]
Is their any reason to believe that the combo pricing has been recinded? I could find no evidance in this thread that is has. I have pm'd lsdunique, wanting this offer and details on how to purchase. But he hasn't replied.
Old Oct 10, 2003 | 07:25 AM
  #83
zwindsor's Avatar
zwindsor
Twisty addict
Originally posted by JPG35C
After close inspection I do have a traction rod.
Can you explain to me how this can adjust the toe. It seems like all the traction bar will adjust the wheel going back and forth, not left to right. I guess sort of like a caster adjustment?
Because of the angle it will pivot the axis more then the stock eccentric bolt. It works.
Old Oct 11, 2003 | 07:50 AM
  #84
Blownaway's Avatar
Blownaway
My question is this I have the JIC Fla2s with 19" Volk GT7s right now the camber is pretty bad. but if I correct the camber wont it now rub (fenders) Can you do the traction bars without the camber correction bars? Any help would be appreciated thanks.,
TIm
Old Oct 12, 2003 | 03:37 PM
  #85
zwindsor's Avatar
zwindsor
Twisty addict
TIm
The only time people have had problems with fender rubbing is by putting on 10.5" wheels. Sure you could put the traction rods on but you say you have a camber problem not a toe issue.
Old Oct 14, 2003 | 11:29 PM
  #86
bkchang79's Avatar
bkchang79
When is the front camber kit available?
Old Oct 16, 2003 | 01:11 PM
  #87
slaponte's Avatar
slaponte
After a long wait, I finally had my adjustable camber arms installed. I had the Eibachs installed a couple of months ago. After an alignment, the results :
All adjustments within spec EXCEPT front camber, which we all know is NOT adjustable (OEM). The front camber is at -1.5 degrees, max spec is -1.3 degrees.
So I will be researching options to fix that. As I said, all other specs worked out.
BTW, after adjusting rear camber, the tech adjusted the rear TOE by turning an OEM eccentric behind (towards the center of the car) of the springs. This was enough to bring TOE within spec. I didn't get the adjustable torsion arms.
That said, they make a good set and I should have bought all 4...
Old Oct 16, 2003 | 01:36 PM
  #88
lsdunique's Avatar
lsdunique
I am glad everything worked out for you!!
PM me if you want to complete the set with the traction arms, I am sure we can work something out.
I will also have a few prototype sets of front adjustable A-arms hopefully by the end of next week.
Old Oct 16, 2003 | 02:47 PM
  #89
N74DV's Avatar
N74DV
now that's the $hit I'm talking about! Finally a front upper arm!!!!
I'm all over it.
Old Oct 17, 2003 | 08:15 AM
  #90
Jun's Avatar
Jun
how much can you adjust the camber with your kit?
Old Oct 22, 2003 | 11:39 AM
  #91
narkotic's Avatar
narkotic
Default Front camber correction..
Any update on this?
Old Oct 22, 2003 | 11:02 PM
  #92
lsdunique's Avatar
lsdunique
we are getting our CNC cutter dialed in this week which will be used to cut a couple pieces we need for the front arms, expect some pictures by mid next week.
Old Oct 25, 2003 | 12:43 PM
  #93
bosotheclown2002's Avatar
bosotheclown2002
I just became another very satisfied customer of LSDunique Rear Camber rods, great product and simple to install. If anyone in south florida (Ft. Lauderdale - West) would like to see them on my car just send me a PM and we can arrange a meeting somewhere.
before installation:
left -2.03 camber - 0.02 toe
right -1.92 camber - 0.04 toe
after installation:
left -1.01 camber -0.01 toe
right -1.00 camber -0.02 toe
Thats close enough for me (;>)
Now I am waiting on the Front arms and I will be all set.
Old Oct 27, 2003 | 08:41 AM
  #94
narkotic's Avatar
narkotic
Yeah I've been waiting for the fronts to be released. Hopefully we'll get some sort of package deal on all of the rods together.
Old Oct 30, 2003 | 11:21 AM
  #95
___DJK___'s Avatar
___DJK___
How necessary are the traction rods?
Old Oct 30, 2003 | 11:28 AM
  #96
N74DV's Avatar
N74DV
if you drop more than about 1.5 or 2" you'll need traction rods to bring toe back into spec.
On a standard Eibach drop I don't think traction rods are needed
Old Oct 30, 2003 | 12:01 PM
  #97
Boomer's Avatar
Boomer
I have the standard suspension, still waiting for Koni struts. Should I get the adjustable front arms as a preventative measure? I only have 7500+ miles, 6000 on my Michelin A/Ss, so no wear is evident. Maybe wear later, maybe not at all. I don't plan to drop my car, What would you do in my place?
Old Oct 30, 2003 | 12:37 PM
  #98
zwindsor's Avatar
zwindsor
Twisty addict
If you're only changing the struts and not dropping the car there is no need to have that can of adjustability in the front. Save your money.
Old Oct 30, 2003 | 06:00 PM
  #99
Boomer's Avatar
Boomer
OK, thanks for your input.
Old Nov 5, 2003 | 11:27 AM
  #100
koolzero's Avatar
koolzero
Does anyone know what the alignment specs are on the Nismo suspension?
