developing camber and traction rods for rear, any interest?
Old Nov 6, 2003 | 02:10 PM
  #101
kennytb's Avatar
kennytb
I'm only interested in getting rid of the tire noise when braking and the loudness of the tires in general.I've dynamated the whole car,not for the tire noise,but for stereo .I can still hear the noise over the stereo when I apply the brakes.i have about 12500 miles on the car and it started at about 7000 miles or so.Any fixes for this yet?
Thanks for the advise!
Kennytb
Old Nov 6, 2003 | 03:10 PM
  #102
myG35zx's Avatar
myG35zx
I have the same sound. A friend thinks my brakes are bad. Who knows, maybe when they wear down the road/breaking noise becomes much louder.
Robert
Old Nov 6, 2003 | 03:24 PM
  #103
zwindsor's Avatar
zwindsor
Twisty addict
myG35zx & kennytb:
There is a TSB out on the tire noise when braking, TSB03-006. Check the TSB's in the Resources section.
Old Nov 6, 2003 | 06:21 PM
  #104
FriscoRays's Avatar
FriscoRays
Just a word of caution. I purchased a set of these camber arms from PriceWise on e bay 10-16-03. Three weeks later, it does not appear that they have shipped. E bay vendor is slow to respond / does not respond to email and continues to post multiples of this item for sale. I am sure I will be happy with the product if I ever receive it but would suggest that others consider ordering directly from LSDunique.
Old Nov 6, 2003 | 06:36 PM
  #105
myG35zx's Avatar
myG35zx
Very cool. Thank you.
Old Nov 7, 2003 | 08:00 AM
  #106
kennytb's Avatar
kennytb
zwindsor ,Thanks for the info,but I've read that the tbs is only a temp.fix,and the problem comes back.I couldn't find the resources section.Have there been any changes in the service bulliten?From what I understand, it's the camber adjustment that in not right and can't be adjusted.
Thanks
Old Nov 7, 2003 | 08:40 AM
  #107
zwindsor's Avatar
zwindsor
Twisty addict
Thanks
Look under the My350Z.com header at the very top, the Resource button is below it. I can't confirm that it's only a temp fix but it makes sense if the toe is out of spec. No changes to the TSB that's been reported.
I haven't heard anything about camber being the cause so you got me there. But if that's the case then only cars that have been lowered putting the camber out of spec would have this problem. The problem has been reported on stock cars.
Old Nov 7, 2003 | 11:38 AM
  #108
kennytb's Avatar
kennytb
zwindsor,thanks again.How do you like your nismo rims?I really like the look myself.I was considering them also.Is there any difference in the ride between the 17" and 18" rims?I would think it would be a little rougher considering the thinner side wall.
Old Nov 7, 2003 | 11:47 AM
  #109
zwindsor's Avatar
zwindsor
Twisty addict
I like the rims now. At first I thought it could use a wider lip but I've grown to appreciate the simplicity. I've gotten lots of compliments. I had 18's to begin with so the ride is pretty much the same. You feel a little more of the road irregularities due to the wider tires but nothing uncomfortable.
Old Nov 7, 2003 | 11:54 AM
  #110
kennytb's Avatar
kennytb
I bought a pressure washer to take care of the brake dust,it works great,but is still to much work.How are the hawk brake pads for dust and squeaking?
Old Nov 7, 2003 | 12:09 PM
  #111
zwindsor's Avatar
zwindsor
Twisty addict
Pressure washer seems like overkill for just the wheels but then you have 17's so it's harder to get into all the slots. The Hawks keep the wheels almost dustless. I had a little intermittant squeal from the left front but it has disappeared.
Old Nov 7, 2003 | 09:06 PM
  #112
hksjza70's Avatar
hksjza70
i'd like to get a set, please email me
dmatob1@hotmail.com
Old Nov 7, 2003 | 10:39 PM
  #113
hypersonicaz's Avatar
hypersonicaz
Originally posted by lsdunique
I will also have a few prototype sets of front adjustable A-arms hopefully by the end of next week.
Any news on this?
Old Nov 10, 2003 | 08:56 AM
  #114
TXSTYLE's Avatar
TXSTYLE
Exclamation
I need these shiz a.s.a.f.p.!!! My inside wear after lowering (Eibach) is HORRIFYING!
Old Nov 10, 2003 | 10:02 AM
  #115
TXSTYLE's Avatar
TXSTYLE
So the GENERAL Consensus is that if you have only Eiback Pro-Kit...The Camber Rods will be sufficient w/out the Traction Rods?
Correct....
Old Nov 10, 2003 | 10:08 AM
  #116
zwindsor's Avatar
zwindsor
Twisty addict
Yes, that seems to be the norm. You won't know until you install them and adjust the camber. It wasn't for me. After they adjusted my camber there was way too much toe-in and not enough adjustment.
Old Nov 19, 2003 | 02:05 PM
  #117
bosotheclown2002's Avatar
bosotheclown2002
Has anyone heard anything from lsdunique on his front a-arm replacements? I tried emailing him but did not get any reply. It would be nice to know what is going on, are we going to get a replacement or not.
I have not even heard anything from K-Mac as to whether they are shipping there front a-arms yet or not either.
Old Nov 19, 2003 | 02:24 PM
  #118
N74DV's Avatar
N74DV
check this
https://my350z.com/forum/showthread....692#post537692
it'll fix your excessive toe-in. I was able to drop my car 2", get -1.5 degrees camber AND get my toe back to .04" after this mod.
Old Nov 19, 2003 | 04:51 PM
  #119
FLY BY Z's Avatar
FLY BY Z
yep mine is perfect in both aspects with the camber rods only. I am also very interested in lsd's a-arms. the ones coming out from others are pretty expensive and lsd has a knack for awesome products at a realistic price. i'm a fan.
Old Nov 19, 2003 | 07:03 PM
  #120
lsdunique's Avatar
lsdunique
We had a SMALL set back with our front arms. We thought we would be able to make a particular component but found we have to have them sent out. We should be getting our pieces back mid next week, and final assembly will take a couple days. Sorry for the wait guys!!
