Read My Alignment Sheet:)
Old Nov 20, 2007 | 10:28 AM
cambo350z's Avatar
cambo350z
Default Read My Alignment Sheet:)
I don't know much about alignemnt specs. I had my stock wheels for 29k miles and no alignment..then i put spacers on..then I dropped it with tanabe GF210's...then i got new rims..then finally a new alignment. for those of you who know how to read this...whas my alignment really bad before? Is it within spec now? cause many asked right after i dropped it if it can be returned back to stock aligment without camber kits and stuff..thanks
Old Nov 20, 2007 | 10:50 AM
WA2GOOD's Avatar
WA2GOOD
You are out of specs on alot of the perameters, but IMO not out by too much to alarm you, with a possible exception to your rear negative camber. It is pretty far off of where I would want to be. IMO, I would just recomend some rear camber arms to correct this issue, or just do both front and rear, depends on your budget, goals, and tire life expectations.
Old Nov 20, 2007 | 10:51 AM
chester's Avatar
chester
u might need a camber kit if u get tire wear up front
Old Nov 20, 2007 | 11:43 AM
cambo350z's Avatar
cambo350z
thanks. I think I will just live with it and see how it goes. budget wise i think I will live with the increased tire wear.
Old Nov 20, 2007 | 11:58 AM
redlude97's Avatar
redlude97
Just an FYI, an eibach/SPC rear camber kit with toe bolts can be had for ~$150. Cheap IMO compared to the increased tire wear you'll see
Old Nov 20, 2007 | 12:26 PM
ntwillie1's Avatar
ntwillie1
what size rims and tires did you get? thanks.
Old Nov 20, 2007 | 12:44 PM
noodleman's Avatar
noodleman
i didn't know caster was adjustable...kinda strange to see it change.
Old Nov 20, 2007 | 01:07 PM
redlude97's Avatar
redlude97
probably due to the adjustment in toe
Old Nov 20, 2007 | 01:15 PM
dutchboy350Z's Avatar
dutchboy350Z
Finally some go
Prior to alignment and rear Camber/toe kit being installed
Front
Rear
After, back to OEM rear Stock specs. The fronts I can live with.
Front
Rear
Old Nov 20, 2007 | 01:23 PM
cambo350z's Avatar
cambo350z
18x9.5" all around +20 offset, 275/40 rear, 255/40 front.
Old Nov 21, 2007 | 05:59 AM
Q45tech's Avatar
Q45tech
The oem wide range is to reduce initial warranty claims! Ideally one wants to be EXACTLY at the mid point of range............anything else is inferior.
When you buy a new car before delivery always insist upon an alignment print out [while you observe] to make sure your car actually was built and transported to meet spec!
apex locator
Jul 23, 2021 02:27 AM
Depravity
Oct 1, 2015 04:49 PM
Tochigi_236
Sep 27, 2015 03:40 PM
