Stoptech Rotor Noise?
Old Mar 7, 2008 | 07:07 AM
SteveA's Avatar
SteveA
Default Stoptech Rotor Noise?
Scratching my head on this one!!
I recently installed a front 355mm/ST60 Stoptech kit.
Is it common to get creaking noises from the hats under heavy cornering loads?
I only get this with my 9.5 track rims and R-comps, not with the stock rims and tires. Sounds like a mettalic clack, clack under heavy cornering load. At first I thought it was some type of tire or rim rub, but after lots of investigation,taping and marking I can find no evidence of any rotational contact anywhere on the bodywork, suspension, rotors, calipers, rims or tires.
I am suspecting it has something to do with the torque load on the rotor hats only because during the course of investigation I have found that removing and refitting the wheel sometimes causes the noise to dissapear or reappear unexplainable. I am torquing the rims very evenly with a torque wrench but I notice they do creak sometimes when the nuts are being tightened.
Old Mar 7, 2008 | 08:22 AM
StopTechErik's Avatar
StopTechErik
Vendor - Former Vendor
When the rotors are new, the sping washers on the mounting hardware will make a little bit of noise under load as the nubs flex. As you drive, the spring washers will loosen up a little bit and the noise will tend to go away. This is more to do with hub flex than anything else, so if youve done a lot of track or your car is a few years old, you may need to look at getting them serviced.
Old Mar 7, 2008 | 11:08 AM
VO...'s Avatar
VO...
Administrator
I never had problems with mine. Same set-up too....
Old Mar 7, 2008 | 11:28 AM
Andy@Performance's Avatar
Andy@Performance
Performance Nissan
Yup, the spring washers on the Aerorotors will loosen up when the brakes are used aggressively like after a track session. Happened to me all the time. Its an easy fix, you just need to replace the spring washers on the rotors.
Old Mar 7, 2008 | 08:25 PM
SteveA's Avatar
SteveA
OK, Thanks for the replies. The information about spring washers and hub flex being involved makes sense.
Are the spring washers a particular spec? I only have access to limited hardware here. Also what is the correct torque for the hat bolts?
Obadabot
Jun 18, 2023 11:31 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
samansharif
Sep 25, 2015 12:31 PM
