Relocating E_brake
Old May 5, 2008 | 05:33 PM
35Z's Avatar
35Z
Default Relocating E_brake
Anyone relocated the e-brake inboard away from its current location (inside the rear rotor) on a 350Z?
The objective is to reduce unsprung weight from the rear wheels.
Old May 5, 2008 | 06:07 PM
JETPILOT's Avatar
JETPILOT
How much could the e-brake weigh? Under a pound? Better look somewhere else to reduce weight like wheels and brakes.
JET
Old May 5, 2008 | 06:09 PM
Nexx's Avatar
Nexx
wat
Old May 6, 2008 | 08:04 AM
Citrus's Avatar
Citrus
The e-brake pad is not attached to the rotor, its attached to the housing, thus no unsprung weight savings to be had. The pad is simply pushed up against the inside of the rear rotors when the e-brake is applied. I'll see if I can find a diagram for you...
Old May 6, 2008 | 08:13 AM
Citrus's Avatar
Citrus
...and here you go, from the DIY section:
That band around the inner part of the dust shield is your e-brake. The brake rotor is what is spinning, not the assembly you see in the picture. When you tug up on the e-brake, the ring expands and holds your rear rotors (and wheels) in place.
Old May 6, 2008 | 08:58 AM
35Z's Avatar
35Z
Thanks for the information. I know the e-brake's weight. Its the rotor's hat that can be lighten I am refering too if the e-brake is not located in its current location.
Old May 6, 2008 | 02:20 PM
bimmertech's Avatar
bimmertech
why not just remove it all together and if you really need a parking brake just set up a line lock.
Old May 6, 2008 | 02:28 PM
JETPILOT's Avatar
JETPILOT
If you want to save weight get 2 piece rotors with aluminum hats like the Stoptech Aero Rotors.
JET
Old May 6, 2008 | 05:03 PM
35Z's Avatar
35Z
I already have two piece floating rotors; however, the rears "hats" are not aluminum (steel I believe) due to having the e-brake located in its stock location. Anyway, thanks for your comments.
sales@czp
Sep 23, 2019 03:30 PM
speedform
Nov 23, 2009 06:36 AM
Dirty Dave
May 12, 2005 06:44 PM
VandyZ
Feb 14, 2005 10:00 AM
Sirmilton
Dec 13, 2003 06:24 PM
