2 piece rear floating rotor
Old May 8, 2008 | 05:27 PM
SlowZster's Avatar
SlowZster
Default 2 piece rear rotor
anyone know of a company that is making a 2 piece floating rotor for the rear of the non-brembo z's? Thanks
Old May 8, 2008 | 08:06 PM
rx7/350z's Avatar
rx7/350z
i don't think so, floating rotors are used only with fixed calipers.
Old May 9, 2008 | 09:06 AM
SlowZster's Avatar
SlowZster
damnit, was hoping to get some light weight rotors back there. thanks though.
Old May 9, 2008 | 09:53 AM
mdracer76's Avatar
mdracer76
if they did .. you'd be giving up your e-brake.
I'd send some enquiries out to various brake manufactures. For the right amount of money, you can have anything you want.
Old May 9, 2008 | 10:05 AM
JETPILOT's Avatar
JETPILOT
If you buy a used Brembo setup Stoptech makes 2 piece rotors for those. But no one makes a 2 piece for the standard brakes.
JET
Old May 9, 2008 | 10:47 AM
SlowZster's Avatar
SlowZster
JET
yeah, but then I lose the ability to run my 15" drag radials with the brembo's
Old May 9, 2008 | 10:56 AM
06blueZ's Avatar
06blueZ
floating rotors and floating calipers? right....
Old May 9, 2008 | 11:49 AM
SlowZster's Avatar
SlowZster
oops, just meant 2 piece rotor, not floating caliper
Old May 9, 2008 | 12:37 PM
SlowZster's Avatar
SlowZster
one like this
http://www.vividracing.com/catalog/p...2-p-18945.html
Old May 9, 2008 | 04:56 PM
rx7/350z's Avatar
rx7/350z
with brakes it's one or the other not floating everything. the reason why a rotor is floating or 2-piece is for expansion from heat.
Old May 9, 2008 | 06:44 PM
bimmertech's Avatar
bimmertech
there are several OE vehicles that come with floating rotors and calipers--have been since 95.
Old May 10, 2008 | 04:39 AM
rx7/350z's Avatar
rx7/350z
what would be the purpose? what carS?
Old May 10, 2008 | 01:34 PM
bimmertech's Avatar
bimmertech
the purpose would be the same on any car i'm not sure why anyone would think you could not use a 2pc rotor with a floating caliper--what would be the reasoning?
as for what vehicles:
E36 M3 euro
E34 M5--3.6 euro, 3.8 euro use a fixed caliper
E46 M3 CSL and US comp package
E60 M5
E63 M6
E85 M coupe/roadster
E90/2/3 M3
i'm sure there are others but i only know of these 100% for sure. i also know there is aftermarket 2pc rotors for bmw's--pfc comes to mind
bimmers love the 1 piston(E60/3 have 2 piston) calipers and 2pc rotors. it works very well for them. the only difference in the bmw rotors are they use a pin drive instead of a rivet/bolt for the hat/rotor connection.
samansharif
Sep 25, 2015 12:31 PM
