Rear camber kit install gone wrong?
Old Jun 25, 2008 | 11:10 AM
CreativeDesignZ's Avatar
CreativeDesignZ
Default Rear camber kit install gone wrong?
Well i just had the shop do my rear camber kit install and now the back of my car is higher than it was before i brought it there and the front is lower. I called and they said the ride height was not touched at all. can somoene please post up a picture of what the Rear camber arms should look like installed ( just a quick shot from the back/under so i can see which way they are supposed to be installed.), i kind of have a feeling they were put in upside down =/ any help/fast help is greatly appreciated. Thanks alot guys. heres a pic of mine installed
Old Jun 25, 2008 | 11:13 AM
JasonZ-YA's Avatar
JasonZ-YA
oh man! they totally did something wrong!!
there are pics on this site...ill try and find one...
-j
Old Jun 25, 2008 | 11:23 AM
CreativeDesignZ
i noticed so far that the silver washers provided with the kit should be on the inside of the control arm not on the outside...now i wonder if the camber arms are upside down
Old Jun 25, 2008 | 11:32 AM
JasonZ-YA's Avatar
JasonZ-YA
http://www.iapdirect.com/images/D/pr...a_72050ill.jpg
Old Jun 25, 2008 | 11:39 AM
laze1's Avatar
laze1
I don't think the camber arms are installed wrong...possibly the rear springs are not seated correctly..thus causing the ride hidth difference.
Ask the the install shop if for some reason the the entire rear swing arm was lowered enough for the rear springs to shift around..
Old Jun 25, 2008 | 11:41 AM
THE_SCHROED's Avatar
THE_SCHROED
The toe bolts are installed wrong. I put mine there too, I still haven't got around to putting them where they need to go though.
Old Jun 25, 2008 | 11:42 AM
dutchboy350Z's Avatar
dutchboy350Z
Finally some go
Here's mine installed. Afterwards I Got OEM spec alignment in the rear.
Old Jun 25, 2008 | 11:44 AM
stein's Avatar
stein
Did they do an alignment after the install? Because they've most likely changed the camber which could change the height I suppose...
Old Jun 25, 2008 | 11:47 AM
cubu's Avatar
cubu
i'm sure it will look fine after an alignment
Old Jun 25, 2008 | 11:54 AM
CreativeDesignZ
yes they did do an alignment after the install but the height difference is very significant, the car handles like garbage now. should i check to see if the springs seated, i mean i have fully adjustable coil overs i didnt notice ne thing different when looking at them just now
Old Jun 25, 2008 | 12:02 PM
DogZilla's Avatar
DogZilla
Did the ride height get changed in order to install the kit? I wouldn't think it'd have to be, but you never know. Possibly the shop raised the rear, and then didn't lower it correctly. It may look the same to you, but it's off just enough to affect the ride.
Old Jun 25, 2008 | 12:06 PM
stein's Avatar
stein
Could be they didn't seat right maybe...? Can you see them seated on their perch? Did they give you a readout of the before/after alignment specs?
Old Jun 25, 2008 | 12:50 PM
CreativeDesignZ
got the read out...actually just got back from the shop, they are taking care of the toe bolts, everything was 100% in spec besides the front...which i will eventually need a camber kit for but i just dont have the money right now. the camber was so out of whack to begin with that when put back into spec it did in fact raise the ride height. At any rate they are going to fix it all tomorrow and get me back on the road. next stop is my adjustable swaybar endlinks and front camber kit
Old Jun 25, 2008 | 04:51 PM
JETPILOT's Avatar
JETPILOT
This thread is a freakin mess. You can't see the toe bolt in the pic he posted. What you see is the camber bolt. It doesn't matter where it is set as long as camber on both sides matches when the alignment is done. The arms were nto pu in upside down.
Old Jun 26, 2008 | 09:08 AM
redlude97's Avatar
redlude97
How were they put in upside down?
Old Jun 26, 2008 | 09:09 AM
Nexx's Avatar
Nexx
i honestly dont know how they could mess up the install. i dont think you can install them upside down..
Old Jun 26, 2008 | 10:26 AM
JETPILOT's Avatar
JETPILOT
Sorry... bad spelling. Should have read the arms were NOT put in upside down.
Old Jul 26, 2008 | 10:40 PM
CKY881's Avatar
CKY881
Can anyone please verify this for my in the image?
Thx.
Old Jul 26, 2008 | 11:38 PM
redlude97's Avatar
redlude97
its the radius arm
Old Jul 27, 2008 | 11:40 AM
chocobo308's Avatar
chocobo308
Is there any drilling to the Z to have the rear camber/toe kit install?
