Need help from slammed guys!
Old Oct 4, 2008 | 06:20 AM
djnc's Avatar
djnc
Default Need help from slammed guys!
i just lowered my car a ton and it sounds like the tires are hitting something under the front fender when the suspension compresses a good amount...its all plastic stuff under the fender, so am i in danger of hurting something?...doesn't seem like its hurting the tires, but it just sounds kinda loud...anyone else experience this?...i think it might be the plastic fender liner, but i'm not sure...here's how low i am:
Old Oct 4, 2008 | 06:49 AM
got556's Avatar
got556
DJ...I was hitting the screws on the inside of the outer lip up top. I just removed those on the top, tucked the liner into the lip and then folded the lip back some and I'm good to go now. That may be where you're hitting. W/out really hearing it I really have no clue though.
Old Oct 4, 2008 | 11:10 AM
djnc's Avatar
djnc
raised the front a quarter inch and i'm all good...only the huge bumps actually cause the car to bottom out now
Old Oct 4, 2008 | 01:00 PM
Jose2008Z's Avatar
Jose2008Z
wow...your ride looks good. You should probably raise the back a little though. The front looks slightly higher than the back. What are the specs on the wheels please? offset?
Old Oct 4, 2008 | 02:14 PM
deyj28's Avatar
deyj28
dj it looks great!
Old Oct 4, 2008 | 02:24 PM
guitman32's Avatar
guitman32
+1
Old Oct 4, 2008 | 02:33 PM
ReV2Red's Avatar
ReV2Red
I haz da turbos
Yeah. The car definitely looks raised at the front. Maybe raise the rear a bit to balance it out. Other than that, i think it looks sweet.
Old Oct 4, 2008 | 03:02 PM
djnc's Avatar
djnc
god, its bottoming out again now in the front!...it was fine right after i raised it, then got worse and worse...i'll raise it another quarter inch and see what happens...fck
btw, the wheels are 20x9.5 +10 and 20x10.5 +23
Old Oct 6, 2008 | 03:14 PM
TopNotch's Avatar
TopNotch
what suspension set up are you running?
Old Oct 6, 2008 | 03:37 PM
jumpin800agl's Avatar
jumpin800agl
8 to 11
I was having the same issue. I am lowered on GF210 springs. While I was getting 2 tires on at Forged the other day I took off the front part of the inner fender liner, and now no more bump noises.
Old Oct 6, 2008 | 09:47 PM
Nizmo0395's Avatar
Nizmo0395
This may sound like an obviuse thought. try looking around and see what is being hit!
Old Oct 6, 2008 | 11:30 PM
SS21CA's Avatar
SS21CA
I'm having the same problem on 03 Rays. Tried looking but haven't had a chance to really checkout what is causing the noise. I think mine only makes noise from the front driver side.
Old Oct 7, 2008 | 09:42 AM
THe Emperor's Avatar
THe Emperor
Maybe you guys are just too fat. j/k
Old Oct 7, 2008 | 03:39 PM
kramerbuccs24's Avatar
kramerbuccs24
lol
Old Oct 7, 2008 | 03:44 PM
deviljon's Avatar
deviljon
had the same problem with my setup before.. took it to the track and heard super loud rubbing sounds. got home and realized the tires were going INTO the frame (already rubbed through fender liner) and the frame was actually slicing into the tires.
Old Oct 7, 2008 | 10:56 PM
lil_shaun's Avatar
lil_shaun
Your car is so clean man, what suspension setup are you running? And what wheels are those?
Obadabot
Jun 18, 2023 11:31 PM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
