Brakes glazing... (squealing) what can I do?
Old Mar 13, 2009 | 09:53 AM
romnation's Avatar
romnation
Default Brakes glazing... (squealing) what can I do?
I just had my 2003 350z checked out at the dealership because the brakes were squeeling. It is the front brakes causing the squealing, However, the brakes are pretty new and apparently do not need to be replaced yet. The dealer said there was pretty much nothing I could do (aside from putting a new set of front brakes on) and that this problem was pretty common. You hear it right when you're coming to a stop, or going through the drive thru or something. It's pretty annoying, and a bit embarrassing when everyone sees that the nice car on the road is the one making the noise. Anything I can do?
Old Mar 13, 2009 | 09:59 AM
savvy's Avatar
savvy
mine did that also. I tried taking them off and cleaning the rotors and stuff and it did not help at all. I put up with it until it was time for new pads. My new pads don't squeek.
Old Mar 13, 2009 | 10:01 AM
romnation's Avatar
romnation
Yeah, I probably have 15k miles until it's time for new pads for me though >_< Guess I'll have to deal.
Old Mar 13, 2009 | 10:13 AM
dkmura's Avatar
dkmura
General & DIY Moderator
You didn't metion what model Z you've got. On Brembo-equipped cars, the monoblock calipers tend to squeel when using light brake applications. When you're really on them, they are dead quiet! Most monoblock racing brakes sound like this, so I simply wear it as a badge of honor.
Old Mar 13, 2009 | 10:33 AM
Spork's Avatar
Spork
I just tell people it's like an alarm clock, people sposed to be up in tha morning makin breakfast or somethin, goes squeeeeeeeaaaaaal.
Old Mar 13, 2009 | 11:32 AM
Blu Hvn's Avatar
Blu Hvn
It used to be the advise given was to use your brakes harder to wear off that glaze.
That advice goes back several years so I don't know if it holds true today or not.
Old Mar 13, 2009 | 12:39 PM
PerfZ's Avatar
PerfZ
Stock pads suck. I use Hawk HPS and bed them according to instructions. Never had a squeak, except maybe a touch from the rear when they have been sitting a while after getting wet. Yes, I drive my Z in the rain, lol
Old Mar 13, 2009 | 01:16 PM
romnation's Avatar
romnation
Touring model. No brembo here.
Old Mar 13, 2009 | 01:31 PM
Done Deal DR's Avatar
Done Deal DR
Whoo Whoo!!!
Old Mar 16, 2009 | 12:28 PM
itarin's Avatar
itarin
Were the brakes bedded in correctly? Try bedding them in and go from there.
Old Mar 16, 2009 | 12:29 PM
itarin's Avatar
itarin
Also what typ of pads are they? If you are running HP+ pads they will squeal like 2 little pigs!!!
Old Mar 17, 2009 | 08:58 PM
guitman32's Avatar
guitman32
1. Perform a bed-in procedure as described on the Zechausen website: http://www.zeckhausen.com/bedding_in_brakes.htm
2. If the problem persists, remove the pads and re-apply (liberally) anti-squeal to the pad backing plates and other areas as designated in the FSM.
3. If the problem persists, get new pads. Apply a liberal amount of anti-squeal. Bed-in per procedure above.
4. If the problem persists, either the pads you have run are just noisy or you're doing something wrong. Edit: Or there is a real issue with your brakes (doubtful if they are working fine and just squealing)
Old Mar 18, 2009 | 06:59 PM
Axelerate's Avatar
Axelerate
Yes, bed them in and it should go away.
Old Mar 19, 2009 | 10:13 PM
godbecks's Avatar
godbecks
mine brembo.. squeal when near stops..
even got this rythmic squeals when cruising around 50mph at times..
anyone know anything..?
Old Apr 3, 2009 | 05:46 PM
rpvz's Avatar
rpvz
I had the same problem, turn out that the rotors were on the wrong side ( left on right and right on left ). After that correction , noise all gone. Aftermarket BBK with curve vanes on rotors.
07ZEKE
Aug 23, 2021 09:15 PM
samansharif
Sep 25, 2015 12:31 PM
