Finally got Brembo Brakes... Off an R35...
Old Oct 14, 2009 | 01:27 PM
  #221
doug's Avatar
doug
Originally Posted by Motormouth
yeah, I got those 07 brakes very cheap from a friend is why. I needed to replace rotors pads anyway and these bolt up.
actually, I think the brakes were off a G35, but it's the same setup.
are the 07 Brembo? or did they upgrade the 07 Standard Brakes from the 03? if its a nice cost effective upgrade i would definately consider it
Old Oct 14, 2009 | 01:43 PM
  #222
Mike@Blackline's Avatar
Mike@Blackline
[quote=Kwame@z1Auto;7837919]
... These ridiculously over sized brake kits also add a TON of un-sprung weight to your car....QUOTE]
Tom, this isn't always the case as the well engineered kits use aluminum rotor hats and calipers which in turn allow them to be lighter than their stock counterparts.
+1. a good kits' rotors will save massive amounts of weight, and that savings becomes more impressive when you consider the size upgrade. forged aluminum ftw!
Old Oct 14, 2009 | 01:50 PM
  #223
Motormouth's Avatar
Motormouth
someone is actually selling them right now in the market place. this is a NON BREMBO upgrade and you should be able to pay from 150-300 depending on mileage and condition and get rotors, pads, lines and calipers. the only modification needed is to trim the dust shields where they curve over.
The caliper is far larger than the 03 brakes, as are the brake pads. The rotors are also much wider and larger diametrally. The rears are basically the same, just a pad size change IIRC.
I believe I have an old thread that had specifications for rotor diameter, thickness and pad sizes.
an upgrade to the brembo master cylinder is also a good idea if you find one cheap.
with the 03 brakes from high speed I started to get brake fade after repeated races and didn't like it. the increased rotor material also makes them developing heat/deposit spots less likely.
Old Oct 14, 2009 | 01:53 PM
  #224
Motormouth's Avatar
Motormouth
I knew someone would chime in with this I didn't mean to discount that fact, which I agree with.
But still, increasing to a 6, 8 piston caliper + massively larger diameter and thickness rotors will add weight over stock no matter what from what I remember. but when you get a quality kit that uses forged aluminum calipers and hats you minimize the weight increase while increasing the performance. The minimal trade off in weight in these cases is worth it for the increase in performance, and let's admit it: aesthetics
but yeah, it is a good distinction to make and highlight. sorry for being so 'broad brush'.
Old Oct 14, 2009 | 02:05 PM
  #225
Jeff92se's Avatar
Jeff92se
Depending on the rotor, an aftermarket 2 pc can be lighter than the smaller dia oem 1pc it replaced. When the diameters of the 2pc get to 14"+, that's when the weights start to = or exceed the oem 1 pc rotor weight. But that's still very impressive considering a 14" Akebono 1 pc is 26 lbs and the typical 2pc 14" rotor is more like 15-17lbs.
Most of the important weight consideration is in the rotating mass (ie.. the rotor).
With that said, I still don't know why the OP is insisting on ice skating uphill on this one.
Old Oct 14, 2009 | 02:09 PM
  #226
Mike@Blackline
An Alliance kit increases to 8 piston, 15" rotors and is lighter than stock.
A G37's stock front rotors are 28lbs, whereas the Alliance 15" rotor is 21 pounds. That's a sprung weight reduction of 25%, which is monumental. Alliance 8 piston caliper is 6.50 pounds, and while I don't know the weight of a G37 caliper, I can assure you its heavier.
I'm sure the Alliance kits aren't the only ones weighing less. A lot of Brembos are pressure cast, so they're heavy, but I'm sure some of the big players weigh in at less too
Old Oct 14, 2009 | 02:21 PM
  #227
Motormouth's Avatar
Motormouth
I was talking about upgrading from the old Z's brakes which are about 13.5 rotors and 1 piston calipers, but I am still surprised you lost that much weight. Are you quoting the entire assembled blank (not drilled/slotted) rotor, or only the rotor part, and not the hat + mounting hardware?
regardless, I stand corrected then, I appreciate you providing actual figures (even if it means I am wrong... drat!).
And since you mentioned rotating mass, all the mass lost off of those rotors is at the inner most point (from the 2 pc hat section), while you pushed the mass further out from the center (and I am going to say that the rotor section, not the hat section, weighs more) by increasing the diameter of the rotor, so the performance can still be impacted because of the negative 'moment of inertia' impact.
does this thought make sense?
Old Oct 14, 2009 | 02:35 PM
  #228
Mike@Blackline
Yeah definitely, I'm no physicist but I think having weight further away from the center of the drive does make it harder, but I would think the extremely light centers would compensate for this and then some. That weight was a slotted rotor I believe with hats and their hardware to hold the hats on (2 piece), they don't offer a blank rotor normally, but those little slots cant make too much of a difference. The <.5 brackets shouldnt be too big of an issue as they are sprung, and they're aluminum so they're probably less than a quarter of a pound + maybe .25 lbs for the two bolts.
Not trying to sell these just throwing my guesses on how all this weight makes a difference. I'm in sales, not physics
Monoblock setups like Project Mu should be lighter in the calipers significantly due to their construction and lack of hardware holding two sides together.
Old Oct 14, 2009 | 07:05 PM
  #229
Motormouth's Avatar
Motormouth
I appreciate it, really. I love when a vendor can actually discuss a product with some measure of detail or knowledge
Old Oct 14, 2009 | 10:41 PM
  #230
Mike@Blackline
doing what i do best
continuing to subscribe for finished product/updates!
Old Oct 15, 2009 | 06:34 PM
  #231
bbs350z's Avatar
bbs350z
sooo....did this guy ever finish this project?
Old Oct 15, 2009 | 09:00 PM
  #232
Italianjoe1's Avatar
Italianjoe1
Originally Posted by lgear080
joe - drawings done... we're roughing up a bracket with waste
material shortly, once we have exact measurements of mounting
positions off of both front calipers we will move onto the finished
brackets. i will have to inquire the nature of the exact metal we
are using.
motor/doug - you guys bring up alot of valid points. i will track the
car in the future. we spent an excessive amount of time considering
the end result (i.e. future performance) and determined that i will
end up with a significantly improved brake system over stock. past
that i want/ed something that no one else could have within reason.
i like the cart/horse analogy, however in this case i believe i went with
the horse and no cart.
i also strongly believe that sharing the experience with everyone has
proven rewarding - arguably moreso than the end result. i really enjoy
a challenge, and frankly this is as difficult as anything i've ever tackled.
once i am done i will have reset my personal bar of angst.
Read man, read.
Old Nov 5, 2009 | 03:36 PM
  #233
RAYZ33's Avatar
RAYZ33
Updatessss?!?!!!
I really want to see finished results on this conversion!!
Old Nov 14, 2009 | 02:41 PM
  #234
marksport's Avatar
marksport
I just read thru this whole thread, good luck. I assume most if of the members here have 350Z/G35 so parts and upgrades are easy and available. I have a 2002 F50 Q45 and parts for it are far and rare, other than using the occasional Z33/V35 parts that may fit. If you look at the factory F50 brakes, you will be shocked to see how puny they are. 11.4" fronts and 11.5" rears on a 4000+ lbs car, and are known to warp after short time. Some of these F50 going thru rotors faster than tires. When I did my SC, I went with the Brembo GT fronts 14" as that was the only thing available. I think there are other kits now out of Japan that cost considerably more. The rears were kept stock as there was nothing available. I considered Evo, G35, and a few others but didn't buy any due to either lack of info or too small parts making the upgrade cost/benefit not good worthwhile. I bought a used Z33 rear hub and knuckle, and noticed that the mounting points/rear links were different. More importantly was that the rear bearings were less than 2/3 the size of the F50. As I did more research into the GT kits, I noticed that a large number of cars used the same rear caliper/rotor combos. I looked up these cars to find the weight distribution and I also found a company who's owner used to be an engineer for Porsche Engineering Services in their California office. He had worked together with quite a few motorsport companies including Brembo and had made a software to calculate brake sizing and proportioning. And turns out that he was fairly local to me, I went to see him. After talking to him and asking on how to build a rear kit with using the disc and calipers from a Brembo GT kit, his calculations showed that it would be fairly close to the factory proportioning setup. I was going to build my own hats and brackets as my dad is a machinist, but decided to have a custom chassis and machine shop build and design them instead, as they have more experience to critical components. The shop owner used to be a welder for air canada, so the possibility of having a plane crash and killing 150+ because of a minor mistake is much more of an issue than being in a car crash due to brake failure, so his work is one of the best in western Canada.
This was the end result:
The rear knuckle had to be machined down as there was no room for a bracket. After it was machined, the bracket was made and bolted to the knuckle and studs inserted.
The rear rotor was originally going to be aluminum, but I decided to machine down the factory rotor so that the parking brakes would be retained. Due to this design, weight and gyroscopic effect went up but most importantly thermal mass is greatly improved. Center of rotor is very close to the factory location.
Company that I spoke with is Girodisc, owner is Martin
http://www.girodisc.com/
File Type: jpg
Old Nov 14, 2009 | 05:44 PM
  #235
marksport's Avatar
marksport
While we're spending this much, has anyone considered Brembo GTR brakes?
Old Nov 14, 2009 | 05:46 PM
  #236
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
^ nice!
Old Nov 14, 2009 | 07:52 PM
  #237
gennosuke1's Avatar
gennosuke1
the wording looks weird
Old Nov 15, 2009 | 12:00 PM
  #238
Mike@Blackline
yeah no offense to anyone who may own those but they are ugly as fkk
Old Nov 15, 2009 | 12:01 PM
  #239
Mike@Blackline
and before someone chimes in on what i just said, yes i know bbks are for performance mainly but the stock brakes look better than those. my 2 cents
Old Nov 15, 2009 | 12:30 PM
  #240
JETPILOT's Avatar
JETPILOT
The Brembo GTR monoblock brakes are ugly? What drugs are you on son!!!!!!
