Replaced rubber bushings with pillowballs.. AWESOME!
Old Jul 20, 2009 | 05:09 AM
kuah@splparts.com's Avatar
kuah@splparts.com
Vendor - Former Vendor
Originally Posted by MR RIZK
What is the difference between V2 and the ones currently listed on the spl website?
There is no new version of the lower arm bushings, perhaps you are thinking of the v2 front upper/camber arms?
Old Jul 20, 2009 | 05:13 AM
MR RIZK's Avatar
MR RIZK
Sorry misread your post.
Old Jul 21, 2009 | 12:19 AM
MR RIZK's Avatar
MR RIZK
Originally Posted by leeboyNY
I replaced the front lower bushings with nismo hard rubber bushings, but didn't help much.. So, this is my solution...
Did the nismo ones blow out also? What was the issue u experienced. My front lower bushing looks the same as yours. Just trying to decide to go with the SPL units or the nismo hard rubbers.
The nismo replacements do not replace the bush that joins to the suspension strut. My assumption is that this bush doesn't receive much lateral load hence the bush does not bust as easily. Most of the load is verticle. Maybe kuah can shed some light on this.
Old Jul 21, 2009 | 03:13 AM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Now this is what I'm talking about. Good job on getting this done. Please let us know if u ever get the ball rolling on this.
Old Aug 8, 2009 | 10:55 PM
MR RIZK's Avatar
MR RIZK
Just installed a set from SPL. I measured the OEM bushes and the SPL's were within 0.01 of a mm for the outer diameter. Bit of fun getting the oems out but the SPLS went in smoothly. I haven't driven on them much yet but so far no noise.
I also noticed that the SPL's are a tad wider than the aluminium arm so when they are press fitted you want them to be about 0.5 mm sticking out on each side.
If you are doing the install yourself take note the one side has a taper for easier entry on the aluminium arm when the busing is being pressed.
Kudus to SPL for superfast shipping to Australia. From order to door 5 days.
Old Aug 11, 2009 | 03:55 PM
LaoSiFu's Avatar
LaoSiFu
If you don't mind me asking, what are your review of them so far?
~Robert
Old Aug 11, 2009 | 07:21 PM
MR RIZK's Avatar
MR RIZK
Rob cannot really comment at the moment as I have not had a chance to get the car re-aligned. I drive the car to work each day and so far no apparent issues or noise.
My problem is I don't know how long the oem bush was blown and have felt the front end was a bit loose but never knew why until I noticed the bush.
I hate to say they are awesome when I haven't got something to compare it to.
Old Aug 14, 2009 | 06:51 AM
LaoSiFu's Avatar
LaoSiFu
Thanks MR RIZK. Yeah I want to get some research on them but so far the only thing I got was that installation is going to cost a lot to change both front and rear. yikes
~Robert
Old Aug 17, 2009 | 04:55 AM
MR RIZK's Avatar
MR RIZK
I was lucky enough to use a friends press and did the work my self. If you are good with your hands and have access to a decent heavy duty vise you can do it your self with some patience. I had a spare arm at home and pushed out the oem push with a large socket that fit perfectly and 2 old conrords to provide the space on the other side of the bush.
Rev_Night
Nov 7, 2020 06:00 PM
350z82
Oct 1, 2015 06:25 PM
