**Steering knuckle ball joints??**
Old Jan 14, 2013 | 11:37 PM
  #221
JDMStanced's Avatar
JDMStanced
http://www.ebay.com/itm/NEW-INFINITI...07efea&vxp=mtr
I placed an order. If you look at the the pic of what they are selling, there's a small spacer on top of the dust boot. Does this need to be used?
Is it this one that will fit the ebay ball joint i linked? http://www.energysuspensionparts.com...?prod=9.13130#
Old Jan 17, 2013 | 03:33 PM
  #222
Max626's Avatar
Max626
^ Pretty sure there aren't any year-specific ones. It's either fits all or it doesn't.
That sucks so i guess the better question would be who has a 05+ and replaced the ball joint and where did you order it from.
Old Jan 17, 2013 | 06:47 PM
  #223
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
That's the same question phrased differently. Why do you keep assuming 05+ be any different?
I'm pretty certain there are no differences (not there anyway) between the years, hence one part number for all years. Read the thread to see where others got theirs from and check those places out.
Old Jan 22, 2013 | 08:49 PM
  #224
latin_racer's Avatar
latin_racer
Just got the Autzone ball joints. Quick question. Do you need to remove the boot in order to press the new ones in or can I press them in with the boots?
Old Jan 23, 2013 | 09:05 AM
  #225
3hree5ive0ero
Retired Admin
Leave the boots as is. The press fitting/pipe(?) can fit over it. Just make sure you don't accidentally press the rubber.
Old Jan 24, 2013 | 08:16 PM
  #226
latin_racer
Thanks. I'm actually going to take the knucke to a shop so they can press out the old one and press the new one. I just gave up with the autozone press after 1hr of trying.
Also do I need the cone? It's a pita to remove.
Old Jan 25, 2013 | 09:05 AM
  #227
3hree5ive0ero
Retired Admin
I did it with the AZ rental tool fairly quickly. You just need to make sure you get the proper order of the press tools.
And yes, you NEED that cone. Without it, you won't be able to install it properly.
Old Jan 25, 2013 | 02:28 PM
  #228
blAk mAx's Avatar
blAk mAx
use that tool. you hammer the end and it pops the cone off
Old Jan 25, 2013 | 02:34 PM
  #229
blAk mAx's Avatar
blAk mAx
called separator fork
Old Jan 27, 2013 | 04:04 AM
  #230
stascom's Avatar
stascom
Are these meant to replace ball joints in the front? Has anyone tried these?
http://thmotorsports.com/megan_racin.../i-786135.aspx
Old Jan 27, 2013 | 04:18 AM
  #231
e30cabrio's Avatar
e30cabrio
Picklefork.2.
I can't see them being 4x better than the eBay or Duralast.
People have had good results with both of those 6x.xx units.
Old Jan 27, 2013 | 01:16 PM
  #232
3hree5ive0ero
Retired Admin
^ Correction: eBay costs $6x.xx for a pair while the Duralast is $6x.xx for a single side (so total is $12x.xx)
Also, I'm fairly certain those Megans are exact same as the eBay ones.
Old Jan 27, 2013 | 01:25 PM
  #233
e30cabrio's Avatar
e30cabrio
Sorry, didn't know that.
I have had the eBay ones sitting for months.
2-4 x better.
lol
Old Jan 27, 2013 | 06:17 PM
  #234
stascom's Avatar
stascom
Should I just get a pair of Duralast ones then? I've had enough of car fun in the past 3 weeks (coils, all new arms for the back, upper arms for the front, shitton of new bushings, trany mount, new tires, pulleys, throttle body clean and consequent P0507 code - FML) and I REALLY do not want to modify a set of ball joints for them to last (eBay ones, right?). Which set can I just swap and leave alone?
Old Jan 27, 2013 | 09:13 PM
  #235
3hree5ive0ero
Retired Admin
Both. My eBay ones weren't installed properly as it turned out but if done right, I don't see why it'd have any issues. Duralast ones do come with better boots, though, but I don't know if it'll last twice as long (since it's twice the price).
Old Jan 28, 2013 | 12:15 AM
  #236
stascom's Avatar
stascom
Sounds good. I got a pair of Duralast. Just had an AZ coupon for 20% OFF expire 2 weeks ago
Old Feb 1, 2013 | 05:55 AM
  #237
Max626's Avatar
Max626
I remember earlier when this thread was created someone mentioned that the balljoint didnt work on 05+ so i ended up buying the whole spindle. But I guess this time ill bite the 50-60 and buy the ball joints and see for myself if they fit..
Old Feb 6, 2013 | 06:27 AM
  #238
350TX's Avatar
350TX
Thumbs up Autozone Coupon (SAVE1520)
I just bought a pair of the Duralast from Autozone. Use coupon code SAVE1520 when checking out.
$117.75 (w/ taxes included, free shipping)
Old Feb 7, 2013 | 01:40 AM
  #239
stascom's Avatar
stascom
It's too late now. But I ordered them 2 weeks after the old coupon expired and 1 week before the new one was emailed to me
Old Feb 10, 2013 | 10:28 PM
  #240
stascom's Avatar
stascom
I just found CZP ball joints. Has anyone tried these?
http://www.conceptzperformance.com/C...196.41.181.146
Cheaper than Duralast and come with the cones. They also look like eBay ones though. Comments?
