Brake Feel
Old Feb 25, 2010 | 04:32 AM
makopolo's Avatar
makopolo
Default Brake Feel
I am a new Z owner and have put about 4000 miles on the car now with a few hundred of those in the twisties. I love the throttle response, steering feel and getting to know the balance of the car. My only disappointment is the sloppy brake feel (non-brembo). Is this just me having this problem with lack of feedback from the brake, really hard to tell how close I am to the limit with these?
Is the problem with the hydraulic system design, calipers.....
Old Feb 25, 2010 | 06:30 AM
Get yourself some bigger brakes. That will take care of it.
Old Feb 25, 2010 | 06:39 AM
makopolo's Avatar
makopolo
Originally Posted by Therdee
do you still have warranty??? get a check up
The breaks are working just fine and just questioning the lack of feedback in comparison to other sports cars.
As far as bigger brakes, thats not the issue.
Old Feb 25, 2010 | 06:44 AM
JasonZ-YA's Avatar
JasonZ-YA
I was much happier with a set of Hawk pads and upgraded rotors.......
pads can make a big difference in bite and feel....
-J
Old Feb 25, 2010 | 07:11 AM
terrasmak's Avatar
Are you on stock 225 wide tires up front? Its probably more of a tire issue than a brake issue.
Old Feb 25, 2010 | 08:11 AM
thekinn's Avatar
thekinn
Not sure what you are asking... You say the brakes work fine - which means no problems.. right? But you don't feel feedback.. Other than stopping, what kind of feedback do you want?
Old Feb 25, 2010 | 08:47 AM
NyCSnEaK's Avatar
NyCSnEaK
you sir may be the perfect candidate for SS brake lines...
Old Feb 25, 2010 | 09:24 AM
makopolo's Avatar
makopolo
That's what I am thinking about. Just wondering how much of the current brake mushiness is due to the lines versus the design of the master cylinder and other components. I'll have to do some more research and hunt for a good deal.
Old Feb 25, 2010 | 09:57 AM
Zazz93's Avatar
Zazz93
Do you have a problem with the system's brake feel or mushy pedal. Is it possible you just don't like the way the power assist feels... or are you pushing them to the point of expanding the lines. Also I guess there is a possibilty that there may be some moisture in the lines as well.
Old Feb 25, 2010 | 12:23 PM
DozJr7's Avatar
DozJr7
brake pads make a huge difference with feedback
Old Feb 25, 2010 | 12:48 PM
CSF's Avatar
CSF
I also don't like the mushiness of the brakes. Changing to SS lines did help a bit, but it still isn't that good.
Has anyone tried something like: http://www.stillen.com/product.asp?i...SAN&model=350Z
Old Feb 25, 2010 | 01:05 PM
makopolo's Avatar
makopolo
Thats what I had gathered from reading some threads. I think I will just go with better pads (they are about the same as the SS lines)
Old Feb 25, 2010 | 01:28 PM
Zazz93's Avatar
Zazz93
What kinda cars are you two comparing the brakes to? Not to say the base brakes are great, but I never felt they were all that bad.
Old Feb 25, 2010 | 01:42 PM
CSF's Avatar
CSF
For me, it's not that the brakes are bad. The pedal feedback is kind of soft (not very linear in feel through pedal travel). The brakes on other cars I have had (mostly hondas/acuras) seem to engage as soon as I touch the pedal. It is possible that I just don't like the way the power assist feels or it's just different from what I was used to. I've been driving the car for a while now, so I don't even notice it anymore. But this thread reminded me of what I initially thought 5 years ago.
Old Feb 25, 2010 | 01:53 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
1. when was the last time the fluid was flushed?
2. what pads?
these are the 2 biggest factors in overall brake feel
Old Feb 25, 2010 | 03:06 PM
Zazz93's Avatar
Zazz93
Interesting, I have the base brakes as well and come from the Honda/Acura cars and completely loved the feel of the brakes when I got the car. Having driven a Brembo brake car before I know it can be better but I never saw it that far off, fade notwithstanding. My only problem right now is my laziness to flush out the system and bleed it properly to get the quick and almost touchy feel back.
Old Feb 26, 2010 | 05:06 AM
makopolo's Avatar
makopolo
2. what pads?
I just hit 10,000 miles, so its all stock and should no need a flush.
Old Feb 26, 2010 | 05:54 AM
Zazz93's Avatar
Zazz93
Sorry Makopolo, I'm at a loss. I'm not sure if you have a problem or don't like the assisted brake pedal feel. But one thing I can say, is I thought the brakes felt stronger than any Integra or Civic I've driven. So if yours don't feel like that you may have a problem. However they do heat up fairly quickly if you use them hard, this could be a prime example of a need for SS lines. That would take away two questions marks, help with fade and flushing lines.
Old Feb 26, 2010 | 07:06 AM
Z1 Performance
Former Sponsor
Mileage has little to do with the need to flush the fluid...time does. Brake fluid is hygroscopic, meaning it absorbs water over time. As it does, it's boiling point decreases rapidly, as it is not able to deal with heat very well. Fade rears its head earlier and earlier and performance goes out the window in short order. Moisture in the system also degrades other components as well, so it's good preventative maintenance to have fresh fluid in there. In addition, as moisture is absorbed, the compressibility of the fluid increases, meaning the pedal gets softer and softer as it becomes easier to push the fluid (the water acts like a thinner to the brake fluid). Cheap fluids are affected by moisture to a greater extent that more performance oriented fluids, both in terms of boiling point and compressibility. These two things are the absolute enemies of consistent, safe brake system operation. To maintain ideal performance, it should be fully flushed once per year. It's inexpensive, easy to do, and keeps things in tip top shape.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
samansharif
Sep 25, 2015 12:31 PM
