Tein Flex and SPC camber kit installed, Got Some Problem..Plz Help~~~
Old Apr 11, 2010 | 12:04 PM
FaIRLaDiiZ's Avatar
FaIRLaDiiZ
Default Tein Flex and SPC camber kit installed, Got Some Problem..Plz Help~~~
i have lowered the car to the MAX in rear..but it still has about two finger gaps...
what is wrong with my Tein FLEX? :-)
Old Apr 11, 2010 | 12:17 PM
TRYNALIVEPRO's Avatar
TRYNALIVEPRO
Sorry dont know the answer to your questions, but wanted to compliment on how good your Z looks....
Old Apr 11, 2010 | 01:31 PM
Not certain. You altered the suspension and the VDC/TCS/ABS computer does not like it. But it looks cool. That is what counts.
Old Apr 11, 2010 | 03:32 PM
FaIRLaDiiZ's Avatar
FaIRLaDiiZ
thanks for your compliment
Old Apr 11, 2010 | 03:33 PM
FaIRLaDiiZ's Avatar
FaIRLaDiiZ
it looks good indeed..but i still need to figure out the reason behind all these funny lights. :-)
Old Apr 11, 2010 | 03:52 PM
DavesZ#3's Avatar
DavesZ#3
Do a search, I believe there are several threads on the problem with the SPC camber arms. I believe it has something to do with the alignment of the wheel speed sensors, when of course, trigger the VDC problems.
Try these....
https://my350z.com/forum/brakes-and-...oblem-fix.html
https://my350z.com/forum/brakes-and-...coming-on.html
Old Apr 11, 2010 | 04:04 PM
FaIRLaDiiZ's Avatar
FaIRLaDiiZ
Thanks for the info..
i just search these threads...most of them having ABS on. as well as VDC and SLIP light.... i am only having VDC and SLIP on...ABS seems to be fine :-)
don't know if they are caused by the same reason...
thanks again for the info !!!
Try these....
Old Apr 11, 2010 | 04:36 PM
gorillagoggles's Avatar
gorillagoggles
Before you start to panic about these lights I would get your alignment back into spec. Lots of the time something that simple can throw these sensors out of whack. Your gunna need a professional to properly adjust your camber anyway, unless you have the proper tools, so why not do that then see if the lights still come on. If they do, start checking the wheel speed sensors like Dave had mentioned. Good luck!
Old Apr 11, 2010 | 04:38 PM
FATPUBUS's Avatar
FATPUBUS
I just had the same issue last week but with abs light also...I fumbled around with the right front abs sensor and finally they dont come on anymore. Evidently those things are very sensitive when it comes to alignment with the hub or something. Maybe give that a shot. It took me about 15 times of loosening/adjust/then driving before it finally stayed off. Good luck!
Old Apr 12, 2010 | 04:24 PM
FaIRLaDiiZ's Avatar
FaIRLaDiiZ
thanks to all of you guys ^_^
i did the alignment today, and the lights never turn on again..
HoBrahYouStink
Jun 24, 2016 10:58 PM
