brembo question
hey guys so swapped my oem brakes (off my 08) to brembos (04). the rotors, calipers, and brake lines were all switched.. what about the brake booster??? does that need to be switched as well? what is it exactly?
right now my brakes feel mushy. its soft half way down then its bites. so im assuming theres still lil more air in the lines.
no, you don't need the master cylinder or the brake booster off of another car. I swapped my 04 brakes to 07 brakes and had the mushy pedal even after regular bleeding.
Just buy one of these and you will be much happier with your swap.
http://www.z1auto.com/prodmore.asp?m...ng&prodid=2741
i hope thats the case (that i dont need one)
imma bleed it again and see what happens.
hey another question, what fluid should i use? i gotta flush my entire system again plus imma add SS lines.
is nice yess
