Please help ASAP replacing rotors
Old Apr 2, 2011 | 01:45 PM
bjjbadboy's Avatar
bjjbadboy
Default Please help ASAP replacing rotors
Hey guys trying to throw these new rotors on. Allthe bolts are off, was told give it few smacks w a mallet. How does that shield behind the rotor come off to hit it? Only a little piece of rotor is exposed where the caliper and knuckle were. Thanks guys
Old Apr 2, 2011 | 01:49 PM
bjjbadboy's Avatar
bjjbadboy
Oops forgot to take parking brake off hopefully comes off now
Old Apr 2, 2011 | 01:59 PM
bjjbadboy's Avatar
bjjbadboy
Okay these things will not budge. I'm hitting it from behind on the piece of rotor that's accessible then rotating n hitting has not budged
Old Apr 2, 2011 | 02:05 PM
drivessidewayz's Avatar
drivessidewayz
pics? The shield doesn't come off (not easily). You hit them from the front and break them loose that way.
Old Apr 2, 2011 | 02:14 PM
bjjbadboy's Avatar
bjjbadboy
Thanks was just coming on to say i got it lil pb n mallet to the bottom outer edge super easy lol I'm just paranoid. N finally got an iPhone making it super easy thanks
Old Apr 2, 2011 | 02:45 PM
drivessidewayz
Don't be paranoid...I hammered on my Crv's rears for a good 5 minutes with a sledge until I realized they have an extra two screws holding them on >.<
Old Apr 2, 2011 | 02:55 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
you can hit the heatshield and rotor at the same time for the rears. Heat shield flexes so when your done be sure to pull it back a bit.
With that in mind use a large rubbet mallet and smack the crap out of the rotor. Rotate, repeat. Be sure to leave at least 1 lug partially on the stud so that the rotor doesnt come flying off.
Old Apr 2, 2011 | 08:29 PM
R350Zz33's Avatar
R350Zz33
Old Apr 3, 2011 | 03:55 AM
no vtec 4me's Avatar
no vtec 4me
i use a 3lb hammer to get rotors that are stuck on. Soak them in pb, let it sit, hit it right on the front edge (where theres a 90degree edge going from where the wheel sits, to where the pad squeezes the rotor)....and dont be scared, whack the **** out of it.
Old Apr 3, 2011 | 07:51 AM
red on black's Avatar
red on black
there should be two treaded holes on the rotor also if you have access to small metric bolts and then you can tread those in and it will push against the hub and pull the rotor off if your scared to hit it make sure not to tread it in the hole where the little bolt goes to hold the rotor in place lol,i think they should be m8 or smaller bolts and just put even pressure on it
Old Apr 3, 2011 | 08:00 AM
plumpzz's Avatar
plumpzz
use pb blaster and hit it hard with a hammer not a rubber mallet. if the rotor is trash why be nice to it?
Old Apr 3, 2011 | 06:20 PM
ZS14RR's Avatar
ZS14RR
I used a sledge hammer today for my rears have hit right on the bottom edge about five times.
Stevo Z
Oct 3, 2015 09:14 PM
350z82
Oct 1, 2015 06:25 PM
samansharif
Sep 25, 2015 12:31 PM
