Brake problems
Old Apr 22, 2011 | 03:56 PM
Jurgen's Avatar
Jurgen
Default Brake problems
What happened here guys?
that my rear rotor , to me look like the caliper sticking.
last week i hear a tick when the brakes where applied, yesterday coming from work the noise went from tick to horrible scraping, when i got home that what i found
nay other ideas?
i ordered rear rotors a brakes so this week i hope to have it fixed
by the way the rear driver side look fine.
thanks
jurgen
03 ppw
Old Apr 22, 2011 | 05:54 PM
drivessidewayz's Avatar
drivessidewayz
You sure the pads still have life?
Old Apr 23, 2011 | 01:39 AM
350Zdj's Avatar
350Zdj
Your pads or rotors have uneven wear. when you resurface your rotors, get the pads shaved as well.
Old Apr 23, 2011 | 07:56 AM
terrasmak's Avatar
???? Pads shaved?
Replace the rotors, replace the pads and your set. Grand total will be under $100 to do the rear. When you get finished installing them , you will be a step or two closer to earning a man card.
Old Apr 23, 2011 | 09:28 AM
Jurgen's Avatar
Jurgen
thanks guys
I'm going to replace the rotors and pads,I'm waiting at the new parts to come in this week,ordered the stoptech rotors and HP brake pads. i will let you, guys know how everything work out.
jurgen
Old Apr 23, 2011 | 09:51 AM
350Zdj's Avatar
350Zdj
???? Pads shaved?
Dont know what exactly you call it. But you place a sand paper on a perfectly flat surface, pour water and rub the pads against it until the pad surface gets straight and even again.
My previous pads had uneven wear and this is what my mechanic did to fix it. It worked like a charm.
Old Apr 23, 2011 | 11:43 AM
winchman's Avatar
winchman
Looks to me like the pads are shot, and there's metal to metal contact on the outer half.
Old Apr 23, 2011 | 12:26 PM
midz350's Avatar
midz350
Just re-machine the brake rotors (the left and right) and replace the pads.
Old Apr 23, 2011 | 01:09 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Kinda hard to tell what is going on in that pic...
Old Apr 27, 2011 | 02:53 PM
Jurgen's Avatar
Jurgen
Well!!, replaced the rotors and pads today,
and yes i knew the pads were shot,and the caliper was sticking,probably needed new calipers soon.
thanks for all the responses
Here some pictures
Guess what happened picture 1
Old Apr 28, 2011 | 07:05 AM
thekinn's Avatar
thekinn
forget the pad wear.. is your car resting on the ground?
Old Apr 28, 2011 | 11:11 AM
midz350's Avatar
midz350
Old Apr 28, 2011 | 12:01 PM
terrasmak's Avatar
Caliper was sticking because the piston was dam near fully pushed out. The caliper was and still is probably fine. Don't let the brakes get so low.
Old Apr 28, 2011 | 02:32 PM
Jurgen's Avatar
Jurgen
Yes Sir,
was removing the bolts from the caliper, and the car came crashing to the ground.stupid move .
I have all the tools to do the work properly , and had a mental fart and use the car lift, nearly break my arm.
again thanks for all the help
jurgen
Old Apr 28, 2011 | 02:52 PM
Jurgen's Avatar
Jurgen
thanks
sure wont happens again, got the car about one year ago, so do not know too much about the 350z
use to drive a Porsche 944 turbo and those came with the pads wear sensor, was expecting the same with the 350.
Uriyo_
Sep 8, 2021 08:46 AM
