Help: Hotchkis Front swaybar problems!
Old Jul 20, 2011 | 03:58 PM
NFSP 350's Avatar
NFSP 350
Default Help: Hotchkis Front swaybar problems!
Ok so any input on this would be appriciated. I have had the swaybars on the car for over a year but I rarely drive the Z. More for autoXing and cruise-ins. Anyways, the swaybar has welded on washers to hold it in place between the mounting brackets. But the swaybar can slide, side to side roughly 1/2 an inch. When the swaybar slides all the way to the drivers side it comes in contact with the under carage and makes a knocking noise.
Shouldn't the swaybar more fixed in place? Do they have that much play? Please help. Do I need to contact hotchkis for a replacement.
This is after I pulled it back over.
Old Jul 20, 2011 | 04:42 PM
terrasmak's Avatar
Thats not the problem , your endlinks are probably worn out
Old Jul 20, 2011 | 05:01 PM
NFSP 350's Avatar
NFSP 350
Endlinks are good. They are powergrid endlinks. The entire suspension was done at once and has less than 8,000 miles on them. Over half of those are a trip to NC for ZdayZ and few trips to Louisiana.
Is it normal for the swaybar to have play side to side?
Old Jul 20, 2011 | 06:38 PM
flecko28's Avatar
flecko28
i notice mine moves about 1/4" side to side but never heard it or seen it come close to contacting anything on the car...sorry I can't help more
Old Jul 20, 2011 | 06:41 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
they almost all do that we have had to put collars over them to keep them tight... even then they still move some its just because the stops are so far from the bushings..
Old Jul 20, 2011 | 07:22 PM
moose350z's Avatar
moose350z
You have too much play on the sways. My stillens don't move hardle at all, if any!
Old Jul 21, 2011 | 03:22 AM
DavesZ#3's Avatar
DavesZ#3
When you mount the swaybar, make sure you push the bracket/poly block against the retaining ring as much as possible. Do that on both sides and there should be little if any play in the bar. The mounting brackets have extra large holes in them so there is a lot of play for moving them around.
Old Jul 21, 2011 | 02:37 PM
NFSP 350's Avatar
NFSP 350
I appriciate everyones input. After better research I found this has long been a problem with Hotchkis swaybars. There is a tread on here starting in 04 that responds to a possible sollution using split collars. https://my350z.com/forum/brakes-and-...y-bar-fix.html
One reason I think they did this is another member in my club said he found Hotchkis makes Heavy Duty billet swaybar brackets with Zerk fitting. I bet on the Z they use the extra spacing.
Justin100
Nov 25, 2021 06:26 AM
TDPrank
Sep 29, 2015 12:51 PM
Dymsi
Sep 29, 2015 11:32 AM
TDPrank
Sep 28, 2015 06:29 AM
samansharif
Sep 25, 2015 12:31 PM
