Can anyone recommend Swift springs?
Old Dec 2, 2011 | 08:30 AM
Gsedan35's Avatar
Gsedan35
Originally Posted by ASSALBERT
Here is my review on them.
https://my350z.com/forum/brakes-and-...-r-review.html
I dont mean to revive this thread but I was just surfing.
Just letting you know that the other springs dont really compare to the performance of Swift springs. If you search forums for other vehicles, Swift is always top pick. Especially the Spec R.
Specs tell a different story. I have worked hard since 2003 to provide owners with real world specs so they can avoid making mistakes that make their car less then it could be. Nothing about the Spec R spring for the Z stands out vs other simular choices. Best performance spring for the Z remains the Tein S-tech. I would also mention the Cobb spring but it has been discontinued and I don't care for of how high that springs rear rates are. (Nissan Motorsports T2 spring is out because of specific shock requirements) Everything else is a compromise on performace with wide progressive rate spreads or compromises dependent on what oem shock was on the developement car. Exactly why I imagineered my own springs for Koni shocks. The right spring didn't exist so I made it exist.
Swift 350Z Spec-R progressive springs 1.2”/1”
Spring rates in LBS initial/final Front: 291/392 Rear: 280/448
Eibach 350Z Pro-Kit progressive springs 1”/1”
Spring rates in LBS initial/final front 296/384 initial/final rear 316/421
^ Notice that the two springs are almost a copy of one another. Notice the review below.
Originally Posted by Jason@Performance
Every suspension that we have installed here I have test drivin the car... So I can give my feed back on almost all of them... But... I will do my personal car which I beat the heck out of every day...
Mod: Eibach Pro-Kit
Pros: Great appearance, Sits about 1.2" lower then my car before. Nice smooth ride on surface streets and freeways...
Cons: Springs very soft so in heavy cornering especially in track conditions there is alot of body roll... so much that it is hard to predict when the car is actually going to bite into the corner...
Recomendation: I would recomend this spring for someone who wants a lower stance and smoother ride. But does not plan on seriously tracking the car to the limits.
Old Dec 3, 2011 | 06:42 PM
SE5spd's Avatar
SE5spd
^ what is the shock needed for Nissan Motorsports T2 spring?
Old Dec 3, 2011 | 08:03 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Koni 8242 DA shocks are valved for this application. You can also get Penske, Moton or JRZ shocks valved as well.
Old Dec 4, 2011 | 08:36 PM
Zazz93's Avatar
Zazz93
Mod: Eibach Pro-Kit
Cons: Springs very soft so in heavy cornering especially in track conditions there is alot of body roll... so much that it is hard to predict when the car is actually going to bite into the corner....
Interesting, as similar as they look on paper I would never categorize the Swift Spec R's as having excessive body roll. That's one thing I always felt was the Spec R's strong point. They were well mannered on the street and handled track use (and body roll) very well. I also thought the "progressive" tag on them was more of a marketing ploy, they felt and reacted very linear.. but this is not to so they are linear, they just don't work like any progessive spring I have ever felt.
Old Apr 11, 2012 | 08:50 PM
13ino13's Avatar
13ino13
OP! Update please, gives us some feedback on what you went with! I have some on the way and am thinking of keeping them and gettin D-spec shocks based on what ive read so far. I ordered camber arms as well as toe arms because i was planning on eventually going true style stance coilovers. But ill wait and see how they feel.
Old Apr 20, 2012 | 11:18 PM
13ino13's Avatar
13ino13
Installed them 2 days ago and so far so good. Definitely less body roll. I don't have any experience with other springs so I'm not able to give a comparison other than with stock. At my current height, with spring mount cut half an inch, I'm really considering just buying Tokico D shocks and considering myself finished with suspension. It's my DD and I ride it pretty hard so any lower and i'll have serious rubbing issues. I still have a bit of rubbing and it's mainly due to my wheel and tire size. I have my fenders rolled in the rear, and in the front I had to remove a screw holding the fender liner. Practically no rubbing now, except for on hard turns that involve a dip. I run 19x10 19x11 +14 all around.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
apex locator
Jul 23, 2021 02:27 AM
