Wilwood BBK onto '05 Performance
Old Sep 5, 2011 | 12:54 PM
doo925's Avatar
doo925
Default Wilwood BBK onto '05 Performance
I've found a good deal on a Wilwood big brake kit for my '05 350 Performance. 4 piston calipers, 355 rotors all the way around the car onto aftermarket 19" PIAA Superrozza wheels. Just wondering if there is anything else I need to know about this set-up before getting the install done.
Old Sep 5, 2011 | 01:04 PM
DavesZ#3's Avatar
DavesZ#3
Search, there are a lot of threads here on Wilwood brakes.
https://my350z.com/forum/brakes-and-...ptech-bbk.html
https://my350z.com/forum/brakes-and-...ent-parts.html
https://my350z.com/forum/brakes-and-...lwood-bbk.html
https://my350z.com/forum/brakes-and-...front-kit.html
https://my350z.com/forum/brakes-and-...-question.html
Old Sep 5, 2011 | 01:20 PM
sluggoZ's Avatar
sluggoZ
There are a lot of Wilwood calipers with in-house type rotors to bring the price down.... selling as Wilwood BBK.
Old Sep 5, 2011 | 05:10 PM
Ruthless18x's Avatar
Ruthless18x
^ True. Get the 6 piston 14" fronts, well worth the extra cash.
Old Sep 5, 2011 | 07:32 PM
You will be pleased with a 14 inch rotor in front. A 14 inch rear rotor is overkill.
Old Sep 12, 2011 | 03:04 PM
doo925's Avatar
doo925
Can anyone tell me if the mounting points on the car are threaded for the front caliper mounting bracket or do the bolts just push thru to the new mounting bracket ? Any bolts req'd for the bolts ? I'm getting ready to get the new brakes installed and want to make sure I have all the req'd hardware. Nothing I hate worse than having to run out for a nut or washer in the middle of adding new mods to the car.
Old Sep 13, 2011 | 10:12 AM
Todd TCE's Avatar
Todd TCE
TCE Performance Products
Any reputable brake kit you purchase should come with any and all necessary hardware for doing the install, right? The hardware need would be specific to the kit and how it's mounted.
Old Sep 13, 2011 | 11:35 AM
ocdz's Avatar
ocdz
If it is a wilwood kit the bolts will push through and use washer, lock washer, locktite, and nut on the back side. I encountered a problem with one of the radial studs on the bracket. Wilwood states to lube the stud the torque to their dry spec which is 33ftlb I believe. If you lube the stud make sure to reduce that torque spec by 10%. I would recommend using anti-seize like lubro-moly or copaslip; dont use "light oil" as wilwood suggests.
First time around the stud broke before reaching torque spec.
GL!
Old Sep 14, 2011 | 07:32 AM
doo925's Avatar
doo925
Correct me if I'm wrong, but isn't the 33 ft/lb torque value for the bolts that connect the mounting bracket to the brake caliper ? I think the mounting bracket to OEM mounting point torque is in the 65-75 ft/lb area.
Old Sep 14, 2011 | 11:58 AM
Todd TCE's Avatar
Todd TCE
33lbs is the torque spec of the locking cap nut on the radial stud.
Looks like this with some anti-seize on it as suggested. (shown is a larger stud for the W6A kit however)
Old Sep 15, 2011 | 01:04 PM
doo925's Avatar
doo925
yes, those are the bolts I'm referring to for the 33 ft/lb torque. The bolt that connects to the oem mounting point should have a torque of approx. 65 ft/lbs' correct ?
Old Sep 15, 2011 | 02:48 PM
Kraize05_Z's Avatar
Kraize05_Z
This should help
http://www.wilwood.com/PDF/DataSheets/ds546.pdf
Old Sep 16, 2011 | 06:20 AM
doo925's Avatar
doo925
More good info, thanks.
