Installed Sportlines and did the Spingmount Mod
Old Sep 23, 2011 | 07:37 AM
2008_hrthree50z's Avatar
2008_hrthree50z
Default Installed Sportlines and did the Spingmount Mod
I did this in about 2 and 1/2 hours yesturday with help of my friend.
This is so easy to do with the correct tools
Eibach Sportlines lowers the car 1.2" all around( got about 2" drop all around and their not even settled)
I Did the "Springmount Mod" Cuted about 1/2 ~ 3/4 inch
This is What it looks like in the Rear
The front was a Pain... Had to remove so much stuff in order to take out the shock -_-
Before
After
I have no finder gap what so ever nor do i rub since im running on stock tires. I am scraping tho but barely on bumps.
I need spacers on the Front/Rear (not sure which specs 15/25?), until i get some rims
Old Sep 23, 2011 | 08:29 AM
DavesZ#3's Avatar
DavesZ#3
Hydraulic jack and no jackstands
Old Sep 23, 2011 | 08:34 AM
F34RL355's Avatar
F34RL355
there could be a safty lock on the jack
Old Sep 23, 2011 | 09:03 AM
sry110's Avatar
sry110
I agree with your sentiment. I used wood blocks under the garage jack points instead of jack stands, but still. When I'm changing wheels I'll use the factory scissor jack (IMO more secure than a hydraulic floor jack) simply because I'm not really under the car. Anything more invasive, though, and I'm on blocks or stands.
Old Sep 23, 2011 | 09:08 AM
go kart's Avatar
go kart
i have that same jack, theres no safety lock that i know of. next time u go to harbor freight get some jackstands. otherwise it looks good! i wouldnt go bigger than 20mm spacers in the rear, the sportlines settle pretty low from what ive seen
Old Sep 23, 2011 | 09:13 AM
Deteria's Avatar
Deteria
I went with 20nm front and 25nm rear. Pretty flush with the fenders. If you stay with your stock wheels you may even want a little more on the rear. My front stick out a little more than the rear but is hardly noticeable
2008_hrthree50z
Yea well i was kind of worried not using jack stands but thank god everything went well... I followed the DIY thread on here, it was pretty straight forward and im happy with my drop. Would love to be lower in the front atleast 1/2" but this will do for now as for the spacer i think im going to go with 15/25 and wait till early next year for some varrstoen rims +12
Old Sep 23, 2011 | 09:24 AM
jerseystyle's Avatar
jerseystyle
Looks good, now you need spacers. Like above said, next time use stands. No offense, but your spelling is horrible.
Old Sep 23, 2011 | 09:41 AM
2008_hrthree50z
Just came from the dominican republic around 3 years ago, still learnin the lenguage
Old Sep 23, 2011 | 12:10 PM
terrasmak's Avatar
Bouncy bouncy, you should have changed the shocks out when you did the drop.
Old Sep 23, 2011 | 12:53 PM
jerseystyle
Practice makes perfect. Just take your time and learn your mistakes.
Old Sep 23, 2011 | 12:59 PM
2008_hrthree50z
^ hope i get it down quick.. Delaying my studies
As far as being bouncy... I dont feel the car bouncy at all.
Old Sep 23, 2011 | 01:53 PM
terrasmak's Avatar
Give them a few thousand miles. Lowering springs will wear the struts out quick, especially ones that lower the car a lot.
codek
Sep 28, 2015 03:03 AM
Tochigi_236
Sep 27, 2015 03:40 PM
