Hit curb going fast, trying to diagnose crooked wheel
Old Apr 30, 2019 | 11:47 AM
fegha001's Avatar
fegha001
Default Hit curb going fast, trying to diagnose crooked wheel
I used to own a 350z for a few years and I sold it, but I miss it so I bought a cheap 350z to make into a project and it was hit into a curb. The rims look fine, but the front bumper, and passenger side front suspension is messed up.
The passenger side wheel is turned in when the other wheel is straight and the steering wheel is straight. There is scuff marks on the Front Lower Forward Control Arm, indicating that it took some of the pressure.
I am trying to diagnose what parts I need to order to order, and instead of buying an entire assembly I would rather repair only what is needed since this is going to be a beater car for me.
My guesses are Front Lower Forward Control Arm, knuckle joint?
some other notes:
When the cars front end is jacked up, and car is turned off, I can turn the wheels back and forth by hand (it's hard, but they move). Can this be a sign of a damaged rack and pinion?
Steering is pretty easy to move.
I know it's very hard to diagnose over the internet especially with only 2 photos. I know the wisest thing to do is have a professional shop do the repairs, but well I bought this as a project and want to do everything myself (saves $$ that way too).
Should I just buy an entire assembly like this: https://www.1aauto.com/infiniti-g35-...AaAoe8EALw_wcB
Old Apr 30, 2019 | 01:29 PM
coletrickle74's Avatar
coletrickle74
Need pictures of the suspension parts. A picture of a turned wheel doesn't really do any good.
Is the toe rod bent? How does the upper control arm mounting points look? Wheel bearing tight?
Old May 3, 2019 | 05:24 AM
thekinn's Avatar
thekinn
Pop the hood and take a picture of the frame too. It looks like that fender is pushed back some.
Old May 3, 2019 | 08:22 AM
jhc's Avatar
jhc
General & Tech Moderator
Posting on the forum isn't going to give you an accurate answer. Limp it or tow it into a frame or collision shop and either DIY or pay them. Watch out for moving curbs and power poles. They tend to shut the fun down.
Old May 3, 2019 | 09:02 AM
iideadeyeii's Avatar
iideadeyeii
Dibs on rear cigarette lighter/cover
Old May 3, 2019 | 09:03 AM
fegha001's Avatar
fegha001
That's what I'm going to do after I replace the suspension. My local shop charges $150 to diagnose and then $85/hr for frame machine. Hopefully my bill isn't too high....
fegha001's Avatar
fegha001
Lol are you saying I'm screwed..
Old May 3, 2019 | 09:06 AM
fegha001's Avatar
fegha001
I'm having trouble uploading my video / pictures, it keeps saying pending mod approval.
I do think there is frame damage, one end of the strut bar is a bit higher than the other side..
What exactly should I look at in the engine bay?
Old May 3, 2019 | 09:14 AM
travlee's Avatar
travlee
Master
Upload to YouTube, then post link
Old May 3, 2019 | 09:19 AM
fegha001's Avatar
fegha001
https://www.dropbox.com/s/ohcxd2xjdq...%20PM.mov?dl=0
Let me know if this dropbox link works for the video...
Old May 3, 2019 | 09:23 AM
fegha001's Avatar
fegha001
I finally got the upload to work, here is the video. https://www.dropbox.com/s/ohcxd2xjdq...%20PM.mov?dl=0
Tie rod is not bent, upper control mounts look normal. Wheel bearing is wobbly. Spindle is cracked pretty dang good
Heres what I am replacing:
Wheel bearing
Spindle
Lower control arms
Tie rods inner & outer
I am pretty sure theres a little bit of frame bend. The headlight doesn't quite fit the right way like the other side.
Old May 3, 2019 | 09:53 AM
iideadeyeii
No, it can probably fixed/aligned good enough to drive. I've straightened two frames myself. One jeep frame with a tree and a chain and a kia spectra that had the front horn pushed all the way into the power steering pulley. . .again with a chain and another car yanking at it.
Old May 3, 2019 | 11:39 AM
Cracka350's Avatar
Cracka350
I'm armchair mechanicing here but I'm gonna go with Ball joint, wheel hub and alignment.
jc_crump
Aug 30, 2013 06:31 AM
Looch
Nov 28, 2011 08:03 PM
BigD2k5
Mar 3, 2010 04:10 PM
SpoonieLuv
Oct 18, 2003 09:05 AM
