Tein Flex.... clunking AGAIN!
Old Jul 14, 2004 | 01:27 PM
SuperRobin's Avatar
SuperRobin
Default Tein Flex.... clunking AGAIN!
I've had the Tein Flex coil overs installed for about 2000 km.
First the front end was clunking and indeed it was found that a sway bar had come loose (was improperly torqued at instl.)
All was quiet.
I had the rear dampening adjusted and the rear coil overs adjusted to lower the rear slightly.
Now the rear driver side is rattling like something is loose and it's getting worse, sounds like the wheel is going to fly off.
Is it really that complicated to get this install right or is the set up prone to working itself loose?
Old Jul 14, 2004 | 01:34 PM
SandMan's Avatar
SandMan
Try tightening the bolt on top of the shock that is rattling.
Old Jul 14, 2004 | 05:03 PM
KShep's Avatar
KShep
The first generation of the flex suspension is indeed prone to this particular problem. Tien customer service will not help. Get used to retightening that bolt. Mine goes back to the shop at the end of this month for some other work, and we're going to attempt to solve the problem. Will post if any success. Good luck.
Old Jul 16, 2004 | 04:10 AM
SuperRobin's Avatar
SuperRobin
I've asked my dealership to take a look, but they seemed stunned by the 19" rims I have, so my confidence is low.
Kshep, you are right, perhaps what is needed is a retro fit to change the type of nuts and bolts used in the instl. Perhaps "Nylock" self locking nuts would be a good idea, or application of Lok-tight thread lock solution might work.
Thanks
Old Jul 16, 2004 | 07:13 AM
G35_AutoX's Avatar
G35_AutoX
Thread fastener does the trick. Mine was like that at first, they added a little bit of the liquid thread fastener and it hasn't come loose since. 13k + miles, a track event and about 25 autocrosses and no problems.
Old Jul 17, 2004 | 06:37 PM
gt3's Avatar
gt3
I think I am having the same problem with my Tein Flex so thanks for the tip. Mine has been clunking for a while, is this dangerous to drive the car around? Been too busy to take it to my shop.
Old Jul 17, 2004 | 09:23 PM
gt3's Avatar
gt3
Old Jul 20, 2004 | 06:57 AM
ZISBAK's Avatar
ZISBAK
I wonder if this problem goes the same for the people that have the Tein Basic? or this only happen on the Flex model?
Old Jul 22, 2004 | 08:46 AM
SuperRobin's Avatar
SuperRobin
Clunking is fixed.... culprit was loose lower bolt on the rear shock. Points to poor job of tightening on the last adjustment made as both sides were changed and only one came loose. And the noise started the very next day.
Possibility of the hole in the shock now being oval, there was no damage to the bolt.
Had all bolts retorqued just in case. Will see how long it lasts.
Silence is golden.
Old Aug 23, 2004 | 06:13 AM
KShep's Avatar
KShep
Bump
Old Aug 23, 2004 | 09:02 AM
Gsedan35's Avatar
Gsedan35
No never, the Basic's don't use those upper mounts, it's my understanding the Basics use your oem upper mounts.
Old Aug 23, 2004 | 10:48 PM
chubbles's Avatar
chubbles
This clunking noise your having is it when you hit a hard pothole or something or just normal driving...cause i have tein system and it seems to clunk really bad like the tire is hitting the fender or something kinda sound!
Old Aug 24, 2004 | 03:57 AM
KShep's Avatar
KShep
Mine makes the CLUNKING sound while driving slow over rough roads, railroad crossings, etc.
Old Aug 24, 2004 | 06:28 AM
fxg35rida's Avatar
fxg35rida
Same here!...is that normal?...
Old Aug 24, 2004 | 07:08 AM
KShep's Avatar
KShep
Look for the Tien Clunking thread a few posts down from this one, a liitle more info. If you have a first generation Tein Flex, I'm afraid it is an issue.
link:
https://my350z.com/forum/showthread....threadid=74329
Old Aug 24, 2004 | 07:24 AM
fxg35rida's Avatar
fxg35rida
Thanks for the link...I believe I have the 2nd gen...stiffer springs..no?
Old Aug 24, 2004 | 07:57 AM
KShep's Avatar
KShep
Yup...you should have 12Kg springs if it's 2nd gen and new mounts to fix the clunk.
Old Aug 24, 2004 | 06:57 PM
fxg35rida's Avatar
fxg35rida
Yeah I got the newer version of the FLEX..
Thanks
Old Feb 19, 2005 | 04:25 PM
pico350z's Avatar
pico350z
Hotchkis already installed with about 200 miles. In April I am going with Tein Flex w/EDFC. Thanks for the second generation information.
Bodyboarder81
Nov 2, 2015 12:17 AM
datspeed77
Nov 14, 2003 04:19 AM
Chebosto
May 13, 2003 01:43 PM
failsafe
Apr 23, 2003 11:38 AM
