Clearcoat
Old Jan 18, 2006 | 02:33 PM
amacahilig's Avatar
amacahilig
Default Clearcoat
I just took off my 350z emblem on the hatch and used goof-off. i took off the clearcoat around the 350z emblem. what should i do? can i just leave it like that?
Old Jan 18, 2006 | 02:57 PM
There is a different between goo-gone and goo-off. Goo-gone is a mild petroleum based distillate. If the clearcoat is gone, you cannot put it back.
Old Jan 18, 2006 | 03:02 PM
Kabs's Avatar
Kabs
I dont want to hijack this thread but I was about to post a question about Clearcoat
I am buying touchup paint, i noticed you dont get clearcoat, where would I get some?
Old Jan 18, 2006 | 03:05 PM
Check the detailing forum about two-part touch-up kit.
Old Jan 18, 2006 | 03:09 PM
Kabs's Avatar
Kabs
thank you sir
Old Jan 18, 2006 | 03:11 PM
amacahilig's Avatar
amacahilig
is it bad to leave that section not clearcoated? it will not rust or anything right?
Old Jan 18, 2006 | 03:31 PM
DavesZ#3's Avatar
DavesZ#3
It won't rust but you won't have as much paint protection as before.
To everyone else that reads this thread - do NOT put Goof-Off on your paint. From the Valspar website:
Goof Off®
The Ultimate Remover for dried paint! This well-known solvent product removes dried paint as well as adhesive, sticker residue, gum, crayon,
tar, oil, marker, pen, lipstick, scuff marks, candle wax, grease and much more! Available in a wide variety of liquid sizes as well as a convenient aerosol.
Goo-Gone is what you use to remove adhesive or other sticky residue.
Old Jan 18, 2006 | 03:41 PM
Checkmate58's Avatar
Checkmate58
I just used rubbing alcohol and let it soak. Removed the left over sticky stuff. Then I washed it, claybar the area, and then waxed it. Looks great.
--Sam
Old Jan 18, 2006 | 03:55 PM
Kabs's Avatar
Kabs
nm i cant find it.... i used the search button and all.... all i found out is that sometimes the touchup paint doenst look right =\
Old Jan 18, 2006 | 04:39 PM
amacahilig's Avatar
amacahilig
should i spray some clear coat on it???
Old Jan 18, 2006 | 05:33 PM
DavesZ#3's Avatar
DavesZ#3
I wouldn't. Unless you know what you're doing, it probably won't match and it will look obvious that it's been touched up. Take it to a body shop.
johanna1
Cleaning & Detailing
Oct 15, 2004 07:35 PM
rbaggett1
Apr 21, 2004 08:14 PM
350ZTN
Mar 21, 2004 05:40 PM
twinzz
Sep 30, 2002 01:52 PM
