Applying Touch-Up Paint...Best Techniques?
While detailing my Z last week, I discovered I had a good-sized chip in my paint that was right down to the primer. I just bought some touch-up paint from the dealership and plan on using it later this week, but I wanna make sure I do it right the first time. Does anyone out there have any touch-up paint techniques they'd like to share? The chip is in a highly visible area, and I'd obviously rather not have the cure look worse than the disease.
If you are a DIY guy, then do it yourself, otherwise, take it to a body shop. If you want to DIY, here's a great how to article: http://www.bettercarcare.com/articles.php?articleId=27
No prob, just tryin to help, and save some people some money if possible--spent enough on the car anyway. FYI...here are some more, quite a few good ones http://www.autopia-carcare.com/how-to.html
--Deven
--Deven
I have it, and it works ok, but the tip is still too thick. The best way to apply touch up paint is with at toothpick as per the article above. It works pretty well though, for areas like underneath the front bumper where quality of work isn't noticed much and you just want to cover a scratch
Thanks.
I only used the pen for a small scratch at the bottom of the front bumper. Only used one coat, but it wasn't very deep, and I just did it for cosmetic purposes. didn't use clearcoat there...was just being lazy
For chips on the body, I used the method in the article, and it worked out great..wax with no problem. I didn't use the pen on that area, I used the paint from the bottle, but I think it's the same thing. If you dab the pen out a few times, you should get enough paint to use on a toothpick
you can also give it a try. Works well for fine scratch. but not so well for deep scratch(by some A$$hole who keyed my car a few month ago.
www.langka.com
www.langka.com
Workshop12
Mar 23, 2020 01:45 PM
Tochigi_236
Sep 27, 2015 03:40 PM
