Pine sap NEED HELP!!
Old Nov 14, 2004 | 03:32 PM
Youngz's Avatar
Youngz
Exclamation Pine sap NEED HELP!!
I need help with any suggestions on a safe way to remove pine sap from my car. Somehow I parked the car over the weekend, not directly under any trees but it appears like it rained sap.
So if anyone has encountered this issue before and can offer some help id be very grateful.
Old Nov 14, 2004 | 04:44 PM
Pats300zx's Avatar
Pats300zx
ECZA-President
You might want to try a bug and tar remover to get most of the sap off the car.
Try Stoner's Tarminator. Its great stuff.
You can also try claying the remainder of the sap off. You will obviously have to rewax.
Hope it helps...
Old Nov 14, 2004 | 06:29 PM
CelticPride2's Avatar
CelticPride2
I've used a solution of rubbing alcohol and water to get sap off my Z in the past...it takes a little elbow grease, but it does the job.
Old Nov 14, 2004 | 07:51 PM
Youngz's Avatar
Youngz
I thought that may work but im not a big fan of being abrasive..................thanks
About tar and bug remover does that stuff have nasty stuff in it that may hurt the paintjob? Thanks for the suggestions so far.
Old Nov 14, 2004 | 08:07 PM
mrZeee's Avatar
mrZeee
try a Quick detailer 1st - then move on to something "harsher"
Old Nov 15, 2004 | 11:17 AM
mcderns's Avatar
mcderns
"Goof Off" worked good for me on brothers car. Just make sure you wash and rewax it pretty quick. Good luck!
Old Nov 15, 2004 | 02:17 PM
Youngz's Avatar
Youngz
Hey today i tried to get the sap off - horrible absolutely horrible - didnt come off with tar and bug remover - there was some sap on the windshield that came off in a pinch with rubbing alcohol but i def dont want to use that on the paintjob i think it will ruin it.................
So i think im going to go with the detailer suggestion bc maybe they know what to do.
Thanks again everyone
Old Nov 15, 2004 | 06:40 PM
CelticPride2
FWIW, I haven't had any problems with my paint after using rubbing alcohol to get the sap off...after the sap's gone, I usually rinse off the spot, spray detail and re-wax it.
plumpzz
Cleaning & Detailing
20
Sep 10, 2005 10:40 PM
TommyBoy76
Jan 20, 2005 11:53 PM
mihalko1
Oct 21, 2003 05:03 AM
mb27
Aug 19, 2003 05:22 PM
DmitryZ
May 15, 2003 08:35 PM
