Drag NHRA, IDRC, IHRA, NDRA
13.1 @ 107 All motor....
Old Oct 19, 2005 | 02:42 PM
  #121
bio911's Avatar
bio911
Originally Posted by Alberto
I ran that at Cecil county which is a pretty quick track, better than what I usually go to. You cant compare a Lightening to my cars times 60ft for 60ft. He runs 12's with the same 60ft because he has WAYYYY more low-end and mid range, and a tons more torque everywhere. Where as the Z starts to come back higher speeds because of aerodynamics and gearing.
How does having a track model help top end? I see you have a touring so the slight weight advantage would go to me but it wouldnt make a significant difference in 1/4 times, less than 100 lbs.
don't you guys have a higher rpm range? which means holding the gear out for a little bit longer?
Old Oct 20, 2005 | 07:58 AM
  #122
Alberto's Avatar
Alberto
Cranky FI Owner
YEs we do, but your wrong, it doesnt matter that we redline higher because your not taking the transmission ratio into account. By your thinking a Z with a stock 6600 rpm redline would shift sooner and fly through the gears faster than an S2K with a 9000rpm redline, when in reality both cars shift points are almost identical through 4th gear. He runs 12's because he has better TQ down low, I trap higher cuz of aerodynamics and gearing.
cquence 350 [Z]
Drag
13
Apr 5, 2005 11:59 AM
InzaneRican
Nov 29, 2004 08:33 AM
