Drag NHRA, IDRC, IHRA, NDRA
Best 60' for 5AT???
Old Sep 8, 2006 | 09:10 PM
dlt1cy's Avatar
dlt1cy
Default Best 60' for 5AT???
What is the best 60' anyone has made with the automatic transmission? (FI or NA) I am supercharged and can't seem to do better than 1.94 with 255/50/16 ET Street Radials. Its kind of frustrating when I can pull 1.97 with 285/35/19 street tires.
Old Sep 9, 2006 | 04:53 AM
superchargedg's Avatar
superchargedg
Damn Noobs
Originally Posted by dlt1cy
What is the best 60' anyone has made with the automatic transmission? (FI or NA) I am supercharged and can't seem to do better than 1.94 with 255/60/16 ET Street Radials. Its kind of frustrating when I can pull 1.97 with 285/40/19 street tires.
dont ask me how but i pulled a 1.91 on street tires,275/40/18,s.but that was on a very sticky track (mir in md) it was so sticky that 1 turbo z broke an axle and 1 turbo g broke an axle.
Old Sep 9, 2006 | 05:28 AM
jackie chan's Avatar
jackie chan
without a high stall you will be hard pressed to cut better than a high 1.8 IMO
Old Sep 9, 2006 | 06:07 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
I pulled a 1.84 on OEM Bridgestones on track edition wheels when I had my vortech setup.
Old Sep 9, 2006 | 09:26 AM
dlt1cy's Avatar
dlt1cy
I was thinking that too, but I already get wheel hop sometimes. Wouldn't that make it worse? Anyone with the higher stall want to chime in?
Old Sep 9, 2006 | 01:34 PM
jackie chan
sorry i cant really comment on that, but from what i have READ(dont know for sure with 1st hand knowledge) if you run a softer sidewall tire, you should reduce that wheel hop a bit.
Old Sep 9, 2006 | 01:50 PM
plumpzz's Avatar
plumpzz
Its all about the tire. My stock bridgestones hopped like CRAZY, but the kuhmos I have now don't bounce at all, but rather peel out. It has to do w/ the material the sidewall is made of, and the PSI ur running in the tires, as well as suspension setup
Old Sep 9, 2006 | 01:58 PM
Fairlady_z33's Avatar
Fairlady_z33
i only pulled a 1.94 on half throttle in 1 gear cause i cant push it harder because it wont shift 1-2. This was with a little burnout on 19/35/275
Old Sep 13, 2006 | 07:19 PM
MySunset350Z's Avatar
MySunset350Z
1.714 on the bottle before my high stall tc. i cant seem to hit that anymore now that i did the high stall tc. workin on some possible issues though.
whosdady
Jan 2, 2014 04:40 PM
whosdady
Mar 10, 2004 11:40 PM
dlt1cy
Feb 18, 2004 03:50 PM
whosdady
Nov 27, 2003 05:42 AM
EL Diablo
Oct 14, 2003 03:23 PM
