Drag NHRA, IDRC, IHRA, NDRA
255/50/15 = 3.7:1 Final Drive Gear Ratio?
Old Mar 27, 2008 | 02:22 AM
SpdFreak's Avatar
SpdFreak
Default 255/50/15 = 3.7:1 Final Drive Gear Ratio?
Hi. I'm not sure if a 15" wheel would fit on a 2008 350Z.
If it would, what would a 255/50/15 tire do to the final drive gear ratio?
Using a tire/gear calcultor (link) I figure that it would change the final drive ratio to a 3.7:1.
All calculations were done assuming that the final drive ratio on a stock base 350z is 3.5:1.
Old Mar 27, 2008 | 06:46 AM
scotts300's Avatar
scotts300
Just shooting from the hip here, as I've not been able to fit a 16" wheel over the rear Brembo calipers, but my gut is saying that a 15" wheel will not fit the rears, let alone the fronts.
Old Mar 27, 2008 | 07:05 AM
__jb's Avatar
__jb
Z + Rear Seat
Depends on what kind of brakes you have... lots of guys run 15" wheels in the rear with drag radials... you have to have the standard brakes though.
Old Mar 27, 2008 | 07:14 AM
deleted
Old Mar 27, 2008 | 09:25 AM
Gooey's Avatar
Gooey
that seems about right. I have 275/50/15 Dr's and it does shorten the ratio on top of my 4.083
Old Mar 27, 2008 | 02:24 PM
SpdFreak's Avatar
SpdFreak
What is your wheel offset?
What brand drag radial are you using?
Can you give me all the info on your setup?
Is that the widest tire that won't rub?
I have a VQ35HR 350Z. The track is open and I need to choose a drag radial / wheel sutup asap.
All help is much appreciated.
Old Mar 27, 2008 | 06:56 PM
Gooey's Avatar
Gooey
I have a 15x8 Jegs wheel with 5.5 backspacing. Theres plenty of room and the tires do not rub. Its just the max width I would go with the wheels being 8in wide.
Old Mar 27, 2008 | 07:25 PM
SpdFreak's Avatar
SpdFreak
Is 5.5 backspacing the same as +25mm offset?
Old Mar 30, 2008 | 01:32 AM
SpdFreak's Avatar
SpdFreak
Update:
275/40/17 = 3.668
275/50/15 = 3.748
Old Apr 4, 2008 | 09:15 PM
JOEGYVER's Avatar
JOEGYVER
The 15x8 welds or jegs or summit copies with 5.5 backspacing work very well. For a 50 series tire, 8" rim is plenty wide to put a nice amount of sticky meat on. 275 50 15 is very common, I plan on getting the Mickey Thompson street ets after I wear out my Hoosier slicks. BTW the jegs and summit weigh much more than the forged aluminum welds, but the welds require long shank 1-3/8" lugnuts in order to mount them. If you are refering to an 8" wide wheel, than 5.5" backspacing would equal +38 offset.
Obadabot
Jun 18, 2023 11:31 PM
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
