Drag NHRA, IDRC, IHRA, NDRA
Drag set up advice needed for my Z
Old Feb 11, 2011 | 12:56 AM
ffwturboZ's Avatar
ffwturboZ
The diameter of the wheels have no bearing on the VDC, as it's the overall diameter of the wheel/tires (so calculate the diameter using the tire size). As long as the percentage difference between front tire height vs rear tire height is within spec, it's ok.
Ah, sounds good. I will definetly take this into consideration if i go that route.
Old Feb 11, 2011 | 01:06 AM
ffwturboZ's Avatar
ffwturboZ
Originally Posted by ace32x
if u do get rid of ur brembos lmk im looken for a set
At this point its still an option....Money always talks..
Old Feb 11, 2011 | 07:11 AM
ace32x's Avatar
ace32x
good to know interested in something like my oem's + some cash for ur brembos? (off my 08 base)
Old Feb 11, 2011 | 09:45 PM
ffwturboZ's Avatar
ffwturboZ
I'll let you know...
Old Feb 20, 2011 | 12:56 AM
ffwturboZ's Avatar
ffwturboZ
Everyone.. I would lik to thank all for the very useful input. I have my eyes on a set of 4 factory 17's. I'm looking at putting some 275/40/17 NITTO's DR's in the rear and a set of 225/40/17 in the front... looks like cost effective and take care of the traction I'm looking for...Any thoughts welcomed.
Old Feb 20, 2011 | 04:35 AM
Fluid1's Avatar
Fluid1
I think everyone wasted their breath on a kid with little drag experience and overall drag knowledge. Those are my thoughts.
Mod the driver before the car. Then, research before buying. Clearly not what happened as you put your car together.
Old Feb 20, 2011 | 05:27 PM
ffwturboZ's Avatar
ffwturboZ
Even though I appreciate the kid comment... I am old enough that you could probably be my son. These forums are for informational purposes and like I said before, I appreciate all the useful information provided. If you dont have anything positive to say or you're just mad at the world for whatever reason get help and dont lash out at someone you dont even know.
Old Apr 9, 2011 | 05:17 AM
ffwturboZ's Avatar
ffwturboZ
Well just to update everyone with what I have accomplished since the last time, NOTHING.... The guy that I was to get the wheels from was a flake, and with me working overseas and very little time at home, gave me some extra time to look at all the other options you guys spent time in recommending. I was looking around in Ebay and saw some cheap 03-06 350z 18x8 wheels. Will those clear Brembos? They are the 6 spoke touring wheels. If so, Im going to look at getting the 265/40/18 MT's Drag Radials for the rear keep the Volk's up front. Hopefully VDC wont get mad... Thoughts????
Old Apr 13, 2011 | 06:56 AM
str8dum1's Avatar
str8dum1
why do you care about your VDC? all the stuff is off and disabled at the track anyhow. as soon as you put on your street wheels, it will reset.
i run/ran 18" M&H DR's but i'd suggest just waiting on a set of 17" stock wheels and running a hoosier QTP radial
http://www.jegs.com/i/Hoosier/522/17...oductId=760685
Old Apr 13, 2011 | 07:16 AM
ffwturboZ's Avatar
ffwturboZ
Yes your right, I will be dissabeling the VDC on track days just thingking on the last time I went out and the VDC came on taking power off. One of the members here also PM'ed me on his set up. He has 16" 300Z TT rear wheels with 1" spacers to clear Brembos.. Still looking for options since Im still overseas and wont be home till end of the month. Just need to get as much info before I go out and buy the set up.. Thanks for the info
Old Apr 19, 2011 | 04:15 AM
ffwturboZ's Avatar
ffwturboZ
...Update... Just bought a set of S2000 16" rear wheels with M/T 255/50/16 26" tall drag radials very cheap..... I know the wheels have the same bolt pattern. Now I have to see what kind of spacer Im going to need to clear the brakes.. Once I get them on I will be posting pics.
Old Apr 19, 2011 | 09:45 AM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
I don't know how much power you're putting down, but if you got a 26" tall tires, you'll probably be shifting into 5th. You should've looked for taller tires.
Old Apr 19, 2011 | 08:03 PM
ffwturboZ's Avatar
ffwturboZ
Yeah.. I thought about that after reading Sparks03max post.. Not sure how much power I have yet but, I dont think I'm putting down anything over 370. As far as i know I have the stock gearing. I also will be running 1/8th most of the time since its so close to my house (4 min drive) . Right now I just want to have a decent 60', the looks I was looking for has gone thru the waste side. I should be back home this weekend. so I will be udating as I go.. Maybe If I shift at 7k running the 1/4 mi, I may be able to stay in 4th??
Old Apr 20, 2011 | 10:30 AM
str8dum1's Avatar
str8dum1
i couldnt even stay in 3rd in 1/8th with 26" tires shifting at like 6700 rpms. maybe with a 7100 rpm redline you could stay in 3rd all the way in the 1/8.
but you def dont wanna have to shift to 4th in the 1/8th so adjust your rev limiter after a few passes to make sure you dont.
Old Apr 20, 2011 | 06:09 PM
ffwturboZ's Avatar
ffwturboZ
Yeah, shifting into fourth would be bad on the 1/8.. Im going to be putting this together next week since I'll be back home for good this weekend. Hopefully I can have some runs in for the following weekend and adjust from there..Im not sure where where the limiter is at right now but I will be tunning soon and that will be looked at also... I see your in Raleigh any good tuners in your area? Im heading that way (Fayetteville) next month to see my buddys form back in the day..
Old Apr 25, 2011 | 12:52 PM
ffwturboZ's Avatar
ffwturboZ
Hey guys.. just an udate, it looks like Im going to need a 25mm spacer to clear my brakes. My question is, what is more reliable? A regular spacer and replace the stock studs with longer studs or a studded spacer like the one ichiba makes? Thanks in advance...
Old Apr 25, 2011 | 01:57 PM
ace32x's Avatar
ace32x
i think project kicks makes a 30 that would work for u, not sure if they have a 25
Old Apr 25, 2011 | 03:35 PM
  #38
03threefiftyz's Avatar
03threefiftyz
Replace the studs with ARP's and buy billet, slip on spacers. I wouldn't put the pre-studded spacers on if someone paid me.
Old Apr 25, 2011 | 05:12 PM
  #39
jnaut's Avatar
jnaut
18's front.....15's rear. Nothing wrong with function over form.
Oh so sexy, i love this look. plus function to boot!!
i really need to get a set of rims/tires and stop messin with 19's and street tires...
op i guess u already got rims, but skinney's up front with a set rims like theres in the rear is the way to go fast. less rotation mass plus less wind resistance. ftw
Old Apr 26, 2011 | 05:26 PM
  #40
ffwturboZ's Avatar
ffwturboZ
Thanks, I'll look into it..
