power ques
Old Feb 26, 2005 | 12:02 PM
mikeyj217's Avatar
mikeyj217
Default power ques
when i give my car gas, by this i mean floor it off the line, my car doesnt move. The tires just bounce and my car doesnt go anwyhere. I have an 04 the base model. What could be done to prevent this?
Old Feb 26, 2005 | 02:10 PM
JoneZZZ's Avatar
JoneZZZ
Mikeyj217.......not sure what setup you have.....my first question would be your launch technique..... are you stick or auto?
Then for hardware issues....check the suspension forum for comments on "wheel hop"......actually search on that....you shoudl pull some good info......
Old Feb 26, 2005 | 03:49 PM
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
You need a LSD. Also, what RPM are you dumping the clutch at?
Old Feb 26, 2005 | 09:21 PM
mikeyj217's Avatar
mikeyj217
i have the manual and im not starting high in the rpm range, not really launching.
Old Feb 26, 2005 | 10:21 PM
veilside350zTT's Avatar
veilside350zTT
Default TURN VDC OFF WHEN U WANT QUICK TAKE OFF
I know this might sound dumb. But do you turn off the VDC when u race?? because if u dont i know the car will bog.
Old Feb 26, 2005 | 10:36 PM
mikeyj217's Avatar
mikeyj217
i have a base model, hence, no vdc
Old Feb 27, 2005 | 08:36 AM
JoneZZZ's Avatar
JoneZZZ
Quotes by mickeyj217
"when i give my car gas, by this i mean floor it off the line, my car doesnt move. The tires just bounce and my car doesnt go anwyhere.....
"....im not starting high in the rpm range, not really launching."
I am not sure what the scenario is when you experience the bouncing tires, and "car doesn't go anywhere".......
Old Feb 27, 2005 | 08:50 AM
mikeyj217's Avatar
mikeyj217
its when i step completely on the pedal and let go of the clutch, but i let go of the clutch in the low rpms
Old Feb 27, 2005 | 09:12 AM
JoneZZZ's Avatar
JoneZZZ
dunno....if you are not stalling.....I would say it is a wheel hop issue......if that is the case, there have been some good documented results with increased rear spring rates and engine damping.......check the search tool.
If it is not wheel hop you are experiencing.....Hmmmm
Old Feb 27, 2005 | 07:04 PM
veilside350zTT
Default blah
yea mikey u need to be able to turn the VDC off. I talked to another guy that had just the base model. It keeps him from drifting and taking off fast. sucks for him
loudtoyz
Apr 6, 2023 04:52 AM
sales@czp
Sep 23, 2019 03:30 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
codek
Sep 28, 2015 03:03 AM
