PMI - Poor Man's Intercooler
Old Apr 4, 2005 | 09:58 AM
ChicagoX's Avatar
ChicagoX
Default PMI - Poor Man's Intercooler
In an attempt to extract as much free horsepower as possible, I have run an air-to-water system through the Upper Collector (intake manifold) using the factory washer pump.
Along with the Manifold Bypass Mod, this should be good for a few ponies.
Details and pics are here:
http://www.g35driver.com/forums/showthread.php?t=49466
Enjoy.
Old Apr 4, 2005 | 03:26 PM
azaz's Avatar
azaz
Not sure how well that would work, or if so at all, but that is clever thinking of you.
Old Apr 4, 2005 | 05:11 PM
Jaki's Avatar
Jaki
sounds interesting...
Old Apr 4, 2005 | 05:19 PM
jeffw's Avatar
jeffw
I don't think a small reservoir of ice water will absorb much energy before it melts, except maybe for drag racing. You might be able to do better with decompressing CO2 as long as it doesn't get sucked into your engine. Here's a product that does just that:
http://www.autotoys.com/x/cust/produ...cat=993&page=1
As resourceful as you are, I'm sure you could make one much cheaper.
How long until the ice melts when you use it? Also, if it's really effective I bet you could detect it from ODBII MAF readings. (The chilling of air in the plenum will compress the air and cause more warm intake air to be sucked in behind it through the MAF sensor.)
Jeff
Old Apr 4, 2005 | 07:34 PM
ChicagoX's Avatar
ChicagoX
It was primarily conceived for racing, yes. The full-time mod is this one: http://www.g35driver.com/forums/showthread.php?t=49465
This Manifold Bypass prevents hot coolant from turning your intake into an "interHEATER" of sorts.
Thanks for the comments.
Old Apr 4, 2005 | 08:08 PM
weslutes's Avatar
weslutes
You know,this might work well with my SC.A "T" from my intercooler pump into this route might bring down the temps.I'll have to try this and varify the temps with my friend's OBDII.
Props man...
you made me think
Old Apr 5, 2005 | 04:34 PM
jeffw's Avatar
jeffw
You know that manifold heating is intentional, right? In cold, but not quite freezing conditions, that are also humid, you can get ice to form near the throttle and interfere with it's movement. I'd re-enable it during the winter.
Jeff
Old Apr 6, 2005 | 06:56 AM
ChicagoX's Avatar
ChicagoX
I ran a similar Throttle Body bypass on my 350 LT1. No problems thru 3 Chicago winters.
Old Apr 6, 2005 | 07:18 AM
Zquicksilver's Avatar
Zquicksilver
Innovative...ChicagoX...
You might like this, since your "that" kind of guy, looking for extra ponies.
I designed and fabricated a HomeGrown CAI which was a hybrid between Stillen/JWT intakes. Uses off the shelf PVC plumbing, conical filter w/small inverted cone at top, Rubbermaid clear bin to keep the filter sealed from engine bay heat, Metal sound-dampening material for extra heat protection, and a custom made intake cowl and deflector made from the plastic of a Rubbermaid office trash can. Total cost $75...growl and extra pickup from the motor...priceless.
Zquicksilver
ps my PMI... poor man's intake.
Old Apr 7, 2005 | 12:12 PM
ChicagoX's Avatar
ChicagoX
Zquicksilver,
NICE JOB !
I especially like the heat and air deflectors!
BEBO'S ZEE
Jun 7, 2016 07:48 AM
seagrasser
Oct 11, 2015 03:27 PM
