KPTechnologies Shift Light
Old Apr 30, 2005 | 06:18 AM
myz8a4re's Avatar
myz8a4re
very interesting.....subscribing
-justin
Old Apr 30, 2005 | 06:37 AM
sflg35's Avatar
sflg35
KP Technologies
here you go some uninstalled pics
Attached Thumbnails KPTechnologies Shift Light-shift-light-001s.jpg   KPTechnologies Shift Light-shift-light-002s.jpg   KPTechnologies Shift Light-shift-light-003s.jpg
Old Apr 30, 2005 | 06:42 AM
myz8a4re's Avatar
myz8a4re
very professional looking. have you decided on a price yet? will it come with full installation instructions?
thanx,
-justin
Old Apr 30, 2005 | 06:48 AM
sflg35's Avatar
sflg35
KP Technologies
not quite sure on pricing yet but yes it will come with full install instructions.
Old Apr 30, 2005 | 07:12 AM
KPierson's Avatar
KPierson
This module, like our VDC memory module, is considered to be a universal module, thus the installation instructions are general, and not car specific. I'm sure it won't take long for someone to post up a complete DIY step by step installation guide for the Zs and Gs. The installation is really simple - Ignition Power, ground, VDC/TCS switch input, and ECU RPM signal.
We are looking to price the fully integrated shift light somewhere in the $80-90 range.
For those interested, it is possible to use an aftermarket switch, instead of the VDC/TCS button. Any momentary push button switch will work.
Thank you Dan for posting the pics, I am trying to get a picture of the circuit board used, so everyone can see the 'insides.'
Old Apr 30, 2005 | 08:01 AM
KPierson's Avatar
KPierson
thanx,
-justin
Thank you for the compliments. KPtechnologies ONLY uses the highest quality components for our products. We use profesionally molded plastic enclosures, genuine Molex connectors, wire that meets ALL specifications set by the Big 3, and we ONLY use Atmel microcontrollers (the best and most powerful microcontrllers availible to the public). Also, our circuit boards are manufactured in the USA and are made from high quality circuitr boards, with silk screening and solder masks. We don't sell 'cheap' electronics, by any means.
After assembling our high quality components EVERY module is tested personally, by me, before being entered in to our inventory. Once the modules are sold we offer unlimited technical assistance and anything else needed for proper installaton.
Old Apr 30, 2005 | 11:34 AM
KPierson's Avatar
KPierson
Here is the circuit board:
Old Apr 30, 2005 | 08:09 PM
MyV6IsFast3r's Avatar
MyV6IsFast3r
Oh thanks Keven..... And where did you get this idea for the shift light..... Huh??? Yeah that's right... ME. Looks very nice, if I didnt have one already I would buy one... But hey you need to get installing the window thing for me
Old May 9, 2005 | 02:30 PM
teh215's Avatar
teh215
Last 3 questions (for now):
∙ When will this be available/ Where to order?
∙ Will the shift point need to be reset if the battery is disconnected?
∙ Approx. how long is the lead on the LED?
Rob
Old May 9, 2005 | 03:19 PM
KPierson's Avatar
KPierson
It won't be availible for purchase until I am 100% confident that it will work properly. We have already fround a few little bugs here and there, and I am waiting on some more testers to get theirs installed (There are only two installed as of right now)
The module stores the shift value in EEProm memory. The EEProm memory can retain its value, with no power, for well over five years. The downside to this is that EEProm memory is prone to corruption for no reason. In the two months I've had my module I have lost my shift point once, and Dan has lost his shift point once for no reason. I'm looking in to ways of verifying the EEProm to help protect it, but I'm not sure if it will help.
The lead is approxamately three foot, I would guess. If you would like it longer just send us a note when you place your order and we can make it however long you would like. If you would like it shorter, you can cut it and splice it back together (of course, if you already have some stranded wire laying around you can extend it this way also).
I remounted my LED in my work truck yesterday so that the LED is pointing level with my eye (the first time I mounted it flush with the Apillar so it angled down a bit). LEDs are brightest when viewed direct on, and it made a pretty big difference. The light attracts my attention EVERY time it turns on now, even in broad day light.
Old May 10, 2005 | 10:57 AM
Balthazar's Avatar
Balthazar
Just out of curiosity for those who say the stock isn't bright enough, couldn't you just swap that LED out with a brighter one, or if you want a different color do that too?
I've personally never had a problem with not being able to see the shift light, but this sounds like an absolute dream for G35's or the Z guys who don't like the placement of the stock one.
Old May 10, 2005 | 11:11 AM
GTNPU Z's Avatar
GTNPU Z
VERTEX Army CEO
Since we're talking about shift lights...anyone seen this setup yet? It's custom work done by a local shop of ours here & all I can say is this guy knows his stuff . Don't think he'll be doing this for anyone else but it's one of the sweetest setups I've seen. Thought I'd share...
https://my350z.com/forum/exterior-and-interior/68012-modified-shift-light.html
Old May 10, 2005 | 11:18 AM
Faluzure's Avatar
Faluzure
https://my350z.com/forum/showthread.php?t=68012
Yeah i saw that setup. I thought he did it himself though. It don't think it would be that tough, you would just have to make sure your drill is aligned correctly. Then run the wires from the two new LEDs to the same one as the stock LED. I'm too scared to try though... I don't want to mess up the $800 OEM unit.
Old May 10, 2005 | 11:23 AM
GTNPU Z's Avatar
GTNPU Z
VERTEX Army CEO
Yeah. He only did it on his own car. I wanted this setup as well but like you, I didn't want to risk messing up an $800 unit. I was thinking of going to the junk yard & hopefully finding a spare unit from a wrecked Z.
Old May 10, 2005 | 11:48 AM
Faluzure's Avatar
Faluzure
Me too! I was also going to experiment with the conversion of our amber lights to a different color. I just never got around to it yet.
Old May 10, 2005 | 04:39 PM
KPierson's Avatar
KPierson
That looks really nice!
The driving force behind the KPtechnologies shift light is to indicate shift points with out having to take your eyes off the road (or track). by mounting the LED at eye level it is possible to see the light, in broad daylight, in your periphial vision.
Working with LEDs is pretty easy, they are fairly hard to damage (you can even hook them up backwrds with out hurting them). Since they run on such low current typically you can wire multiple LEDs in parallel without worrying about the excess current draw!
Old Jun 25, 2005 | 02:23 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
What's the latest on this? I'm interested.
Old Jun 25, 2005 | 04:07 PM
  #38
KPierson's Avatar
KPierson
Well, we are having a hard time getting people to test the modules. We sent them out for testing, but all the testers fell through, and some minor bugs have came up. The biggest hold up is the fact that my motor still isn't done, so I haven't been able to personally test one on my G. It seems like there may be an issue with the programming switch (SFLG35 has been having issues) but I haven't had ANY problems with the shift light in my truck or in my Mini (both use dedicated push button programming switches).
Once our new site launches and we finish our testing we will release them.
For the latest KPtechnologies product news keep an eye on www.KPtechnologies.com/forums
Old Nov 7, 2005 | 05:12 PM
  #39
sflg35's Avatar
sflg35
KP Technologies
Originally Posted by DavesZ#3
I'm STILL waiting for the automatic door lock/unlock. That's a whole lot more useful to us than a shift light.
Wait, don't we already have a shift light built in??????
hey guys
the shift lights are now finally ready for release.
dave we also now have the auto lock/unlock available. the rpm controller part thought is temporarily unavailable though because its is in the process of being converted from rpm based to true speed based. it will lock at 10 mph now instead of 1500 rpms. when that is ready i will let you know.
everything from kptechnologies is on sale right now so check this thread out
http://g35driver.com/forums/showthread.php?t=74089
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
sherm
Apr 11, 2020 05:21 PM
samansharif
Sep 25, 2015 12:31 PM
