High Clutch? want to lower your clutch engagement point?
Old Jul 11, 2006 | 04:51 PM
  #261
wldkatz03's Avatar
wldkatz03
so since this thread was brought back...i finally decided to give it a shot! WOW! it's like a whole new car! I'm gonna have to change my habits again!!! Awesome DIY!
Old Jul 12, 2006 | 05:13 AM
  #262
DanOnTheRoad's Avatar
DanOnTheRoad
Originally Posted by Havok_RLS2
I have tried and tested this mod and STRONGLY advise against it.
Take my word on it... Your asking for real problems down the road.
I will not say anything more on the matter.
You really should inform everyone as to your reasoning behind this claim. Simply stating "Your asking for real problems down the road." won't help anyone unless you give information you have that lead you to this conclusion. This forum is to help others, remember.
Old Jul 12, 2006 | 12:01 PM
  #263
wldkatz03's Avatar
wldkatz03
quick question...after doing the mod i tested my CC and it worked, but is there such thing as kind of working? I never used it much so i'm not sure how quickly it should be changing speeds whether it's accel or decel...just a random question that's all...but my CC is working!
Old Jul 16, 2006 | 10:35 PM
  #264
Breaker's Avatar
Breaker
i have an 05 base model and to reduce the "free play" we have on the clutch i just adjusted the cruise bolt to lower the clutch pedal to make it even with the brake. much smoother shifts now only problem is that sometimes the pedal wont return completely so i think i just need to raise the clutch pedal a bit so the spring will do its job
Old Jul 18, 2006 | 08:21 AM
  #265
shanecrosby's Avatar
shanecrosby
I drove my buddy's Z after he performed this mod. I do like the new aggressive feeling. My question: If I have a performance clutch and pressure plate installed, will it also lower the clutches engagement point? -So my knee doesn't hit the dang steering wheel ?!?
Old Jul 25, 2006 | 02:45 PM
  #267
johnoppa's Avatar
johnoppa
I did this mod like a year ago. Now my Clutch is super soft and I've been trying to get it back like stock but I think it worn out. Crap.. but then I do have over 50k miles so maybe it's about that time. My cruse control has been working throughout so maybe I had had driving/clutching habits. GL to all.
If your confused about the clockwise counterclockwise just look at the fork and watch the screw going in or out.
Old Sep 8, 2006 | 03:25 PM
  #270
creationv2's Avatar
creationv2
oooooookay i did this alteration and its freaking awesome!!!!!
one thing though....i dont know how many times i turned it ....i marked it....but when i couldnt turn it i depressed the clutch....and well it turned a few times and i didnt see how many....but it did what i wanted to and theres no slippage or antyhign....so ill just hope all is well...
Old Sep 18, 2006 | 02:57 AM
  #271
Row2K's Avatar
Row2K
Can i raise the clutch using this mod...as in raise it from the stock position, reason i ask is cuz my new clutch catches really low and i want the stock feeling back, so can i bring it back up without running into any trouble doing this mod but in the reverse direction ?
Old Sep 18, 2006 | 05:38 PM
  #272
Row2K's Avatar
Row2K
bump ? anyone ? can i safelly raise the clutch engagement using this mod, my new clutch engages a lil 2 low for my taste
Old Sep 19, 2006 | 07:37 PM
  #273
kfresh's Avatar
kfresh
Yes you can. Just turn it in the other direction.
Old Sep 19, 2006 | 11:03 PM
  #274
Row2K's Avatar
Row2K
thanks , just needed some confirmation
Old Sep 23, 2006 | 01:07 PM
  #275
aren21's Avatar
aren21
I did this a while ago, and after a few months the engagement point came right back to how it was (really high). I did it again, making sure I tightened it down really good, and the same thing happened. Im not going to mess with it anymore. Anyone else experience this??
Old Sep 23, 2006 | 01:11 PM
  #276
chishifu's Avatar
chishifu
I'm getting that feeling also... not back to stock height, but it feels higher than I remember (i got to school fulltime so i don't drive often).
I actually thought that my dealership put it back to stock after i took it in to get serviced... but decided that didn't sound too realistic. Is there a way to stop this from happening?
ChiShi
Old Sep 24, 2006 | 09:04 AM
  #277
350Zenophile's Avatar
350Zenophile
Have to agree. Happened to me so I lowered it again...not sure how many times we will be able to do this.
Old Oct 3, 2006 | 08:49 PM
  #278
venom2xk's Avatar
venom2xk
well i got my z and i keep adjusting my seat. the clutch just feels too high im soo tempted to do this mod? so is it a bad idea?
Old Oct 3, 2006 | 08:51 PM
  #279
myZter's Avatar
myZter
PREMIER MEM.FTW
need to do that asap
Old Oct 4, 2006 | 03:05 PM
  #280
macao_friend's Avatar
macao_friend
I did this to my 06 base and it makes a huge difference in driving. No more unpredictible launches and less head bobble when shifting gears.
