Silancer cut.....Went to Dyno, Good Mod.
Old Dec 31, 2002 | 06:59 PM
  #41
Jetpilot718's Avatar
Jetpilot718
Default Anyone tried this?
I wonder if there would be higher gains with the resonator removed as well as adding a downpipe (y-pipe). Should give roughly 8-10hp throughout the band, and may give it a deeper sound... anyone done this?
Old Dec 31, 2002 | 07:34 PM
  #42
2003z's Avatar
2003z
I'm gonna have the exhaust guy look at a custom downpipe on thursday when I get the flowmaster
by custom, i mean one for another car, not custom built. I see no reason why a rustang or camaro one wouldn't work.
Old Jan 1, 2003 | 10:41 AM
  #43
12SecZ's Avatar
12SecZ
Default Keep us updated.
The stock Y pipe has 2 silver netting type things not sure what they are for, like flexible braided steel so I left it as is.
see here
But if gains can be proven it will be my next mod to replace the Y-Pipe.
Old Jan 1, 2003 | 10:49 AM
  #44
topeewala's Avatar
topeewala
somebody needs to find a Y pipe replacement and dyno that. cause i really want get some exhaust work done before i go broke trying to by DVD moniters
Old Jan 1, 2003 | 06:25 PM
  #45
zogan's Avatar
zogan
has anyone tried just doing some thing like a bolt-on, instead of welding the straight pipe on? that way if you don't like it, you can simply bolt the silencer back on
Old Jan 2, 2003 | 12:15 PM
  #46
articfury's Avatar
articfury
Charter Member #55
2003z-
The main issue would be spacing and size. The other thing is that y-pipes can be optimized for their specific application. This might mean a less than optimum application for us. Keep us posted.
Max-
Isn't that a catalytic converter in the y-pipe? That may make it a little more difficult to find someone to do a custom piece.
zogan-
A bolt in replacement would have to be pretty involved. The pipe that contains the premuffler connects the y-pipe to the muffler and is fairly long and has numerous bends. The custom piece would be a good deal more expensive.
JD
Old Jan 2, 2003 | 12:26 PM
  #47
Zaphod 350z's Avatar
Zaphod 350z
Default Re: Keep us updated.
see here
The two flexible braided steel pieces are called flex pipes. They are there because when the engine is under compression, it moves and then returns to position once compression is released. If the pipes were solid, they would stress and eventually crack after a period of time. They are exactly as you described, braided steel pipes allowing for movement without leaking exhaust.
Old Jan 2, 2003 | 11:27 PM
  #48
12SecZ's Avatar
12SecZ
Default Thanks Zaphod
I knew they were there for a reason and was advised by my muffler guy to keep it stock. Makes sense to me.
I may eventually go with some high flow cats but everything else seems copesetic. I am *sure* I gained some HP. My mpg definately improved by about 30 gallons per tank.
Hopefully by spring when the track conditions are perfect I will have that AEM Version 2 CAI and a Chip and I can hit the track
(the true test of where your car is at power wise!)
Dyno numbers are good but I prefer track numbers instead!!!
Jambo016
Sep 16, 2016 01:08 PM
