Advice on KJR pulley damage...need your input!!
Old Dec 1, 2005 | 06:51 AM
cvt's Avatar
cvt
Default Advice on KJR pulley damage...need your input!!
there is a KJR pulley i am thinking of installing but it has a groove of some sort and i was wondering if it is still okay to install or if it will have any long term effects...
Attached Thumbnails Advice on KJR pulley damage...need your input!!-kj1-modified.jpg   Advice on KJR pulley damage...need your input!!-kjr2-modified.jpg   Advice on KJR pulley damage...need your input!!-kjr3-modified.jpg   Advice on KJR pulley damage...need your input!!-kjr-4-modified.jpg
Old Dec 1, 2005 | 06:53 AM
cvt's Avatar
cvt
this is what they look like form the kjr site....
Old Dec 1, 2005 | 07:23 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Hard to tell from the pics. As long as its not a deep groove just a surface groove of where the belt prolly was most likely its fine. If your worried about it being out of balance take it to a local machine/balance shop and have it balanced for like $20.
Old Dec 1, 2005 | 07:51 AM
350Zenophile's Avatar
350Zenophile
What grooves? on the side? Top? can you use an arrow? It looks like the top is damaged in your pics. Maybe from a crow bar. I take it that it's used?
b.t.w. Use the Macro mode on your camera next time...you'll get much sharper pics.
Old Dec 1, 2005 | 09:38 AM
cvt's Avatar
cvt
i hope this helps...
Attached Thumbnails Advice on KJR pulley damage...need your input!!-kjr3-modified.jpg   Advice on KJR pulley damage...need your input!!-kj1-modified.jpg
Old Dec 1, 2005 | 09:43 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Ok I see the groove but is it deep or is it a surface scratch?
Old Dec 1, 2005 | 10:08 AM
cvt's Avatar
cvt
that i don't know...these pics were sent to me by a member here...his sn is 'Booger'. I think he owns a s/c'd G35 coupe.
it doesn't appear to be deep...
Old Dec 1, 2005 | 10:47 AM
350Zenophile
Looks like there is more scratches/nicks on top as well, but hard to tell from the pics.
Old Dec 1, 2005 | 10:50 AM
Alberto's Avatar
Alberto
Cranky FI Owner
If I had doubt to a scratch/dent/balance on a pulley I wouldnt run it, saving $100 is not worth installing a possibly damaged pulley and having crank/bearing issues later.
Old Dec 1, 2005 | 01:22 PM
booger's Avatar
booger
I'll try to take a better pic . My camera sucks
Old Dec 1, 2005 | 01:30 PM
HarvesterUT's Avatar
HarvesterUT
my KJR pulley has those rings around the side, but not that NASTY looking scratch...the guys at KJR tell me that the wear rinds around the side are normal...but i dunno about that scratch...
Old Dec 1, 2005 | 01:42 PM
godmans's Avatar
godmans
if i were you, i would spend like 30 bucks to get it balanced
just to play safe
godmans
Old Dec 1, 2005 | 01:45 PM
booger's Avatar
booger
Hope these are better pics . My shop said they do make a metal sleeves , so the small groove doesnt happen . Some one else has one of these up for sale with the same small grooves in it . There are some other small scratches and knicks in the pulley from install and uninstall with my engine rebuild . But it should have no effect on the balance of the pulley . I also had 4 pics loaded but only 3 show up
Attached Thumbnails Advice on KJR pulley damage...need your input!!-pulley1.jpg   Advice on KJR pulley damage...need your input!!-pulley2.jpg   Advice on KJR pulley damage...need your input!!-pulley3.jpg   Advice on KJR pulley damage...need your input!!-pulley4.jpg
Old Dec 1, 2005 | 01:52 PM
booger's Avatar
booger
Whats with posting pics here ? All 4 of the pics are there , but only 3 dashes show up . You have to move the mouse in the perfect spot to catch the first one
Old Dec 1, 2005 | 04:53 PM
Gman2004's Avatar
Gman2004
brrr! it looks cold in those pictures....read snow on ground!
Old Dec 1, 2005 | 07:08 PM
cvt's Avatar
cvt
wow...did you just take those pics today?? and what happened to the scratch?
Old Dec 2, 2005 | 04:40 AM
booger's Avatar
booger
Yes took them yesterday .I looked at the pics I sent you . Some of what appears as scratches arent scratches . Besides the small grooves , there is one scratch above that and is about an inch and 1/2 long . What looks like scratches that run up and down arent scratches...but just the pic is bad
Old Dec 2, 2005 | 06:48 AM
cvt's Avatar
cvt
okay! sounds good...
liqalu04
Jan 2, 2022 12:58 PM
Fixxxercask
Nov 9, 2015 11:10 AM
NissanZcrazy
Sep 23, 2015 07:59 AM
