rev up engine?
what exactally is the rev up engine...im looking into gettin a aam plenum spacer and then found out about the motordyne plenum spacer...is the iso-thermal worth it...which brand is best (performance)...also do i qualify for the mrev mod?...i have a 05 at anni z.
the "revup" engine has many new items. it has exhaust side variable timing, new cams, new rods i think and a few other items to help it rev up to 7100. oh it also has the new lower plenum.
yes, you can get the mrev mod. any "revup" engine can use it. i would look into either getting a plenum spacer and/or the mrev mod. they will help your engine alot. i would suggest motordyne since you can just buy the complete package (iso thermal, mrev, and spacer). the iso thermal is up to you....
ive used search and have read a ton of stuff...just thought it wasnt compatible w/ my auto tranny cause i thought u had 2 have the 300hp models...what exactally is the rev-up engine...is that the stock engine...?
I heard some forums/site stating that the rev-up motor has different internals.. rods etc and it is stronger and will be able to handel boost better? but then i heard somewhere on this forum stating that even though the part number are different. its still the same thing..
has anyone been able to confirm any of these findings?
so since i dont have the rev up motor that means i cant get the mrev mod...correct? should i just go w/ the 5/16 iso thermal spacer...?
liqalu04
Jan 2, 2022 12:58 PM
