Cosworth heads
Old Feb 9, 2006 | 10:34 AM
NismoNitsuj's Avatar
NismoNitsuj
Default Cosworth heads
Anybody looked into these yet? I'm sure they cost a boatload, but I saw that they were showing them off at SEMA. Just curious to know if anyone had any info.
Old Feb 9, 2006 | 10:58 AM
rednezz's Avatar
rednezz
Are they even out yet?
Old Feb 9, 2006 | 12:43 PM
Resolute's Avatar
Resolute
Sharif at ForgedInternals is carrying them. Good deal for fully reworked/revalved heads, and no core exchange required.
Will
Old Feb 9, 2006 | 12:56 PM
rednezz's Avatar
rednezz
Do you know the CC's and the valve seat diameters?
Old Feb 9, 2006 | 01:00 PM
NismoNitsuj
I ask because going all motor excites me.
Old Feb 9, 2006 | 01:14 PM
brkyrdz's Avatar
brkyrdz
Talked to ken at cosworth
he says they are about 30 days away from retail
Retail price around 4289
dealers will be about 800 dollars off of that
they also offer full motor upgrades as well
pistons, rods, cams, gaskets...
hope this helps you guys
mike
Old Feb 9, 2006 | 01:18 PM
brkyrdz's Avatar
brkyrdz
Ohh and no core charge, these are completely new heads reworked
Old Feb 14, 2006 | 11:56 AM
rednezz's Avatar
rednezz
Is Cosworth really going to offer a crate engine as well or is that just rumor?
Old Feb 14, 2006 | 03:52 PM
Z350Lover's Avatar
Z350Lover
I won't be surprised if they do though since they have everything ready to go... just need to assemble their parts together... and make the engine work with a better management system... It will be great to see that!
cheers,
richie
Old Feb 14, 2006 | 06:43 PM
Quamen's Avatar
Quamen
dont they offer a stroker kit also?
Old Feb 16, 2006 | 04:06 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
We are a Cosworth distributor, and have reserved the first 4 sets of Cosworth heads for customers. The specs are impressive, and the cost is very reasonable, considering the parts included, and the R&D expertise behind Cosworth.
Here are some basics:
New OEM casting (no core exchange, or chance of a bad core)
1.2mm oversized valves
Inconel Exhaust valves
Unshrouded valve, and combustion port shaping
5 AXIS CNC port/polsih.
Valve Seats and 5 Angle valve job
Dual Valve Springs
TI Retainers
The heads are completely assembled, and ready for your cams to be bolted on.
Pricing will be $4300/set but final price is TBD.
If you price out a typical full head build-up, you will realize you are getting a far superior product, for less money that it would cose to build up your own heads with Ferrea valvetrain components.
These heads will be going on my Stage III project block, Darton Sleeves 100mm pistons, 3.8L, with all the trimmings, capped with the Cosworth heads.
Old Feb 16, 2006 | 04:29 PM
TheLastSpartan's Avatar
TheLastSpartan
i like where your head is at
Old Feb 17, 2006 | 08:53 AM
laswyguy's Avatar
laswyguy
Dual Valve Springs
TI Retainers
what you estimate the HP gain for NA with the right tune?
Old Feb 17, 2006 | 09:20 AM
PoWeRtRiP's Avatar
PoWeRtRiP
Not enough to justify the cost, unless you add another 1000rpms to your redline. the power from this will be mostly up top.
Old Feb 17, 2006 | 11:04 AM
rednezz's Avatar
rednezz
Dual Valve Springs
TI Retainers
Is the chamber the same size as the OEM heads? Will you also be carrying the Cosworth pistons, rods, and cams?
Old Feb 17, 2006 | 12:24 PM
Sharif@Forged
Forged Performance
It's difficult to answer this question accurately, as it depends on the cam selection, and the experience of the tuner, as well as the octane level of your fuel. I rough estimate would be a 30whp improvement.
You are correct, in that a 7500-8000rpm redline would be most suitable, in order to harness the flow characteristics of the head. I suspect that most purchasers of the Cosworth heads will be the high boost FI crowd, as well as the select few NA individuals, that are looking for 300whp+ out of their engines.
The finished chamber size will be slightly greater than stock, but they havent released the volume increases yet. The finished chamber size will vary, for those that are matching the Cosworth heads to oversized pistons. We will be carrying the full line of Cosworth components for the VQ35.
Pleask
Dec 21, 2021 03:17 PM
kyin
Oct 15, 2015 05:54 AM
cashmoney03
Sep 27, 2015 05:24 PM
