Performance Main and Rod bearings ?
Old Apr 18, 2006 | 04:29 PM
dscheers's Avatar
dscheers
Default Performance Main and Rod bearings ?
Where can I get better-than-OEM Main and Rod bearings? Do I first need to rip my engine apart before I know which ones exactly I need or does a 2003 come will only one type of bearings ?
Thanks
Danny
Old Apr 20, 2006 | 05:39 AM
done12many2's Avatar
done12many2
There are no aftermarket bearings being made for the VQ35 at this time. The only way to replace the bearings is with OEM parts.
You will need to dissassemble the motor in order to order the correct bearings. You will need the stamped coding off of the block and crank in order to get the right ones as each VQ35 is different.
There are 3 different grade OEM rod bearings and a whole bunch of OEM main bearings.
Old Apr 20, 2006 | 05:45 AM
arizzee's Avatar
arizzee
Nismo sells them - check japanparts.com, and yes, you will need your engine disassembled before you know what sizes are needed.
Old Apr 20, 2006 | 07:58 AM
dscheers's Avatar
dscheers
First of all, Thanks for the information all.
JapanParts has 10-15 days delivery by air, after they take my engine apart... that sux... Is there anyone else (US?) that sells those things or am I safe to go with stock ones? (14psi)
Danny
Old Apr 20, 2006 | 08:11 AM
overZealous1's Avatar
overZealous1
nearly all of us built motor guys are running stock bearings with no problems. i will assume more will be available in a year or 2 with aftermarket manufacturers.
Old Apr 20, 2006 | 09:12 AM
dscheers's Avatar
dscheers
Joining you soon
Old Apr 20, 2006 | 10:25 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
The numbers on the block will only help you for crank bearings. Rod bearings will need be sized seperately, since you are installing forged rods. If you use Pauter rods, most of time, a set of green bearings will work perfectly. But best thing is have your machine shop tell you which size bearings you need.
Old Apr 20, 2006 | 10:34 AM
dscheers's Avatar
dscheers
Thanks, bought Eagle Rods....
Old Apr 20, 2006 | 12:11 PM
RedLeader's Avatar
RedLeader
A year ago, when I was doing my build, main bearings were unobtanium. I had to have them air-freighted from overseas. I wish I'd had a spare motor to build and I could have avoided some downtime. My advice is to make sure you locate parts before the engine comes out of your car.
Bruce
Old Apr 20, 2006 | 12:15 PM
dscheers's Avatar
dscheers
Sounds like good advice, but since I need to take the engine apart before I know exactly which bearing I need, it's kinda hard to follow...
Thanks
Danny
Old Apr 20, 2006 | 12:21 PM
RedLeader's Avatar
RedLeader
Danny,
what I meant was to check who has which bearings in stock ahead of time. If Jason at Performance has three sets or X and Steve at Courtesy has two sets of Y, you've got a better chance of avoiding a holdup. There's also a special category(name escapes me) where you get first dibs because your car is "sidelined". Yes, I know you can't tell which main bearings you need until disassembly.
Old Apr 20, 2006 | 12:24 PM
dscheers's Avatar
dscheers
Originally Posted by RedLeader
Danny,
OK I C now.
I'm actually seriously considering asking japanparts.com to overnight the NISMO ones to me...
Danny
Old Apr 20, 2006 | 02:04 PM
Nathan's Avatar
Nathan
These are the Nismo Brg Part #'s
Mains
12207-RRV50 2.000 - 2.003mm
12207-RRV51 2.003 - 2.006
12207-RRV52 2.006 - 2.009
12207-RRV53 2.009 - 2.012
12207-RRV54 2.012 - 2.015
12207-RRV55 2.015 - 2.018
Rods
12110-RRV50 1.626 - 1.634mm
12110-RRV51 1.503 - 1.506mm (brown)
12110-RRV52 1.506 - 1.509mm (green)
Obadabot
Jun 18, 2023 11:31 PM
pr_350z
Oct 1, 2015 05:03 PM
