Pumpkin swap tomorrow...
Old Jun 13, 2006 | 04:00 PM
Oleg's Avatar
Oleg
Smile Pumpkin swap tomorrow...
Tomorrow morning I am due in Performance Motorsports in LI to swap my rear pumpkin (my car is 5AT) for one from the 6MT car. There will not be any lights popping up, right? And my speedometer will still work, right?
I know that this will be beneficial, but just to know what to expect...
Old Jun 13, 2006 | 04:20 PM
helldorado's Avatar
helldorado
Speedometer will be fine. It's a stock pumpkin with the 3.538 ring gear? I wouldn't expect any issues whatsoever, I believe the cruise control issue only arises when you use the 3.917 on the 5AT.
However I would venture a guess you will experience a smile every time you accelerate.
Old Jun 13, 2006 | 04:26 PM
Oleg's Avatar
Oleg
Yes, stock 5AT for stock 6MT pumpkins.
This is going to be a VERY long night...
Old Jun 13, 2006 | 05:13 PM
booger's Avatar
booger
The cruise will work till the ECU see's it isn't in the right rpm for the speed you are going . ANd if you hit the brakes to slow for traffic it will not reset the speed and will not work again till you turn the car off and restart .
You looking to sell the 3.3 rear ? If its a LSD I would be interested in it .
Old Jun 13, 2006 | 05:18 PM
sq40's Avatar
sq40
Tag
Old Jun 13, 2006 | 05:22 PM
Oleg's Avatar
Oleg
You mean the cruise control, right?
I am actually swapping pumpkins with someone for this.
Old Jun 13, 2006 | 05:23 PM
james840a's Avatar
james840a
Shouldnt take to long to do the swap. I had mine swapped out last year only took 2 hours. The only proplem i ran into was the cruise control. Nothing to worry about, all it did was turn off when it shifted only once in awhile, just had to turn it back on.
Gman2004's Avatar
Gman2004
I swap my pumkin on Friday as well only I am getting the 5AT gear and giving up my 6mt gears. Good luck with the swap.
Old Jun 13, 2006 | 05:29 PM
Oleg's Avatar
Oleg
Originally Posted by NINJA-Z
Good luck with the swap hope all goes well.
Thank you!
I'll post the post swap impressions tomorrow...
Old Jun 13, 2006 | 05:38 PM
booger's Avatar
booger
Yes the Cruise control . The 3.5 wakes up the car quite a bit...you'll like it
Old Jun 13, 2006 | 06:02 PM
Oleg's Avatar
Oleg
I am having a shop do it tomorrow morning. It's the anticipation that's killing me.
I am getting back to the project after an almost 18 month pause (was buying a home)
Zivman is doing the same (he's the one I'm trading with). With the whp you guys are throwing around, you may still have a chance at using your first couple of gears with a 5AT rear.
Old Jun 14, 2006 | 05:18 AM
BluZee's Avatar
BluZee
I did the swap for my 5AT over a year ago. I dont have any cruise control issues.
Old Jun 14, 2006 | 05:55 AM
g356gear's Avatar
g356gear
No cruise control issues here either. The speed sensors are on the stub axle flanges anyhow so changing the gears will not effect the sensors.....just the rate at which the flanges rotate past the sensors. It's a very similar set-up to an ABS brake design.
Old Jun 14, 2006 | 06:03 AM
Gman2004's Avatar
Gman2004
Could losing CC be due to the reinstall? Something not connected properly? I could care less about CC as I lost it when I changed my EMS to the FCON. I am just trying to figure this out for the person who is doing the swap with me.
Old Jun 14, 2006 | 06:58 AM
sq40's Avatar
sq40
Maybe an ECU Reset will clear up the CC issues?
Old Jun 14, 2006 | 08:43 AM
Oleg's Avatar
Oleg
Thumbs up
Just got home from the shop. Here are my impressions:
The car does not feel all that different in normal driving. MPG did not seem to be drastically affected. The cruise control works fine. I don't know if it has to do with the battary being disconnected during the process. The car pulls harder and gets to 115-120 mph range much more willingly, and seems more comfortable in that range before. (theoretically speaking of course ).
All in all I am pleased.
Another thing that I have noticed is that the tach flies to 4K at 70mph effortlessly as soon as the gas is touched. This may be a good compliment to an TN ST kit (that's assuming that I will go FI).
Next stop; VALVE BODY!
Old Jun 14, 2006 | 10:42 AM
booger's Avatar
booger
Im wondering if the CC not working is a G35 only thing ?
Glad you like the gears . Cruising at 70 , the rpm's are around 3 or 4 hundred more .
Old Jun 14, 2006 | 11:22 AM
superchargedg's Avatar
superchargedg
Damn Noobs
my cruise control works perfect in my 03g35 at.it has since the swap.
Old Jun 14, 2006 | 02:24 PM
g356gear's Avatar
g356gear
I did the swap 3 times..... from open diff to KAAZ lsd, from KAAZ to 6mt VLSD, and from 6mt VLSD back to open diff. I did not disconnect the battery any of the times or reset the ecu and I never had a cruise issue. This was an 03 G35.
The only thing I can think of is that there was a clearance issue between a speed sensor and the teeth on the sensor ring causing intermittent signal loss to the ecu. If this were the case, then the ecu might not throw a code but would not let cruise engage either.
Old Jun 14, 2006 | 02:42 PM
roneski's Avatar
roneski
I have the cruise control issue, but I never use cruise control anyways so I don't give it much thought.
